An AirQ&EarthQ-LoRa EInk WallSwitch that measures your Air Quality, monitores Earthquakes, measures Temperature
What is planned with this Device:
- EInk Touch Screen 2.7 ' Low power if no Display content changes, No anoying Background light
- A Touch screen which comes native on the display and is controlled over I²C
- Ultra Low Power RTC RV3028 for Low Power Battery Operation wakeup
- Ultra Low Noise MEMS LSM6DSL GYRO+ACCEL for Earthquake Detection-> https://github.com/biagiom/QuakeSense
- Ultra Low Noise MEMS LSM6DSL for movement detection and Tap Detection
- Ultra Low Power Mode TPL5110: Let the Processor sleep with TPL5110 Power Gateing and shut down all that is battery draining.
- 9 physical buttons for moments where you do not wnat to use a touchscreen
- LORA:
- Transmit Air Quality Data on a regular Basis (every 15min)
- Transmit Data when Air Quality changes dramatically
- Recieve Commands to Switch on / off ext Relay
- Switch to Desaster Mode and search for BLE Heart Rate Devices nearby and sent this data via LoRa
This is a cocreation work with https://hackaday.io/movil
Ulrich
pammyleong
Manuel Alfonso
Ai-Thinker
