Fist rough dry test!
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 08/08/2023 at 15:330 Comments
After all the troubles it was finally time to do the first dry test.
There is still much to do but the test looks pretty sparky.
It was a random gcode file that contained only a circle with 30mm diameter. A little too big.
The circle used the center as origin an it is visible that it did move the Z axis down to get from the center to the circle line. Need too look into it.
I hope the sparks distract from the shaky camera.
