Hackaday.io Hackaday.io
Sign up Log in
Analog Light Chasing Robot
Analog robot that uses two light dependent resistors to guide the robot towards a light source, and also reverse if it gets too close
customelectronicsCustomElectronics
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
4 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
276
2
4
5
Team (1)
  • customelectronicsCustomElectronics
Join this project's team
  • Reddit Demo Link
  • Video of the bot in action
ongoing project
ROBOT
This project is submitted for
  • Op Amp Challenge
This project was created on 04/19/2023 and last updated 2 years ago.
Description
This robot uses two LDR sensors to measure the relative light intensity on both the right and left side of the robot. If the light level on one side of the robot falls below a certain threshold the robot sends a signal to the motor on that side of the robot to move forwards. As the light intensity increases the PWM speed control signal to the motor gradually reduces its duty cycle, slowing down the motor (eventually to a complete stop). If the light source starts to approach the robot and gets too close, the motor on that side of the robot will begin to reverse (at first slowly and then more rapidly as the light source gets closer. The robot relies on several op amps to operate: an RC triangle wave oscillator to use as the inverting input of the PWM motor speed controller, an absolute value circuit to create the speed up, slow down, and then speed up effect as the light source goes from dim to bright, a buffer amp to generate a VCC/2 voltage reference, and an op amp as comparator.
Details
Files
Light Following Robot Schematic Pictures.zip
Compressed folder containing PNG images of the schematic for the robot.
x-zip-compressed - 74.47 kB - 07/15/2023 at 07:09
Download
Light Following Robot Through hole V3_2023-04-19.zip
Gerber Files for PCB
x-zip-compressed - 50.72 kB - 04/29/2023 at 06:36
Download
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
James Newton wrote 07/15/2023 at 04:22 • point
schematic?
CustomElectronics wrote 07/15/2023 at 07:12 • point
Just added a Zip file with images of the schematic broken down by functional block. I will try to dig up the exact resistor/capacitor values for each passive in the near future
The 2017 Hackaday Prize
This is a line following robot that is competing in the Robocup Rescue Competition.
Project Owner Contributor
Ev3 Robotics Robot
pets3018pets3018
A 3 DOF robot capable of light-painting on a plane
Light-Painting Robot
katieKatie
We built a robot that can be controlled with IoT or with light sensors.
Tokymaker - IoT Robot
tokylabsTokyLabs
This crude, tiny robot can follow a source of light (like an LED torch).
A Miniature Light Following Robot
ashishnrashish_nr
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Analog Light Chasing Robot", please tell us the reason.
Send message
Remove Member
