ATF1504 CPLD Break Out Board
A breadboard friendly BOB to use Atmel/Microchip CPLD
0 followers
This project is a breadboard friendly BOB (Break Out Board) to experiment with CPLDs.
A CPLD can be used to replace several TTL chips. The software used to develop is WinCUPL which run on old versions of Windows (XP, etc.). The programming of the device is done via a parallel port. WinCUPL can use a parallel extension card (ISA, PCIe, PCMCIA).
module-ATF1504.zip
File contains the complet Kicad 7.0 project with schematics, PCB and Gerber files.
Zip Archive - 604.64 kB - 05/01/2023 at 06:53
Download
