T-Battery-A-2023.pdfDaniel Sheehan's recent paper on the theory of the concentration cell - a device very similar to the bipolar membrane device.Adobe Portable Document Format - 292.65 kB - 09/26/2023 at 13:13 |
Bottom Chamber.stlBipolar Membrane Flow Cell Chamber bottomStandard Tesselated Geometry - 2.30 MB - 09/26/2023 at 08:12 |
Top Chamber.stlBipolar Membrane Flow Cell Chamber topStandard Tesselated Geometry - 2.45 MB - 09/26/2023 at 08:12 |
Electrode Frame.stlBipolar Membrane Flow Cell electrode frame (print 2)Standard Tesselated Geometry - 325.86 kB - 09/26/2023 at 08:12 |
Chamber Cap.stlBipolar Membrane Flow Cell Chamber cap (print 2)Standard Tesselated Geometry - 29.77 kB - 09/26/2023 at 08:12 |
POC Alternitive Inner Cylinder.stl(Optional) Used for direct pH measurement in POCStandard Tesselated Geometry - 11.77 MB - 09/26/2023 at 08:04 |
POC Alternitive Outer Cylinder.stl(Optional) Used for direct pH measurement in POCStandard Tesselated Geometry - 9.52 MB - 09/26/2023 at 08:04 |
POC Alternitive Cap.stl(Optional) Used for direct pH measurement in POCStandard Tesselated Geometry - 227.82 kB - 09/26/2023 at 08:04 |
POC Alternative Base.stl(Optional) Used for direct pH measurement in POCStandard Tesselated Geometry - 171.27 kB - 09/26/2023 at 08:04 |
Flow Cell Frame.stlFrame for the pH gradient flow cell (Print 2)Standard Tesselated Geometry - 1.64 kB - 09/21/2023 at 14:48 |
Flow Cell.stlThe pH gradient flow cellStandard Tesselated Geometry - 3.01 kB - 09/21/2023 at 14:48 |
POC Inner Cylinder.stlInner Cylinder for the Proof-of-Concept deviceStandard Tesselated Geometry - 13.27 MB - 09/20/2023 at 15:00 |
POC Outer Cylinder.stlOuter Cylinder for the Proof-of-Concept deviceStandard Tesselated Geometry - 6.51 MB - 09/20/2023 at 15:00 |
POC Base.stlBase for the Proof-of-Concept deviceStandard Tesselated Geometry - 159.26 kB - 09/20/2023 at 15:00 |
POC Cap.stlCap for the Proof-of-Concept deviceStandard Tesselated Geometry - 260.63 kB - 09/20/2023 at 14:57 |
