This is a handheld model rocket launch controller that has a test mode option which can determine if the leads are properly connected to the engine igniter, shorted, or open.
This is a dual contact switch that emulates what Estes has used in their handheld launch controllers for over a half-century. It consists of a custom circuit board and two AAA battery spring contacts. To engage the switch, you insert an Estes safety key, which shorts the connection between the two contacts. Once I get the instructions written, you will see a picture of the safety key switch assembly. I will also include on this project page a link to the custom circuit boards required for this launch controller.
I built something similar, but using a capacitor discharge when I flew rockets as a teenager. I built it into an AMT tricorder model as the case because nerd. I like both the look and the feature set of this launch controller.
How is that type of key and switch part called? Googling "Safety key" does not yield anything related :(
