AI Audio Classifier Recycle Bin
Recycle Bin that sorts rubbish based on the sound of collision using Edge AI audio classification.
According to the Commonwealth Scientific and Industrial Research Organisation (CSIRO) in NSW, it is predicted that about 50% of all waste could be recycled, but in reality only 10% can be successfully carried out because they are not sorted properly. This is a common problem that we are facing globally. Educational recycling campaigns and implementations of standardised recycling labels have been implemented, but a lot of people still have recycling confusion and the problem persists.
I made a Smart Recycle Bin that can listen to the sound of your rubbish and uses Audio Classifier ML model to distinguish the collision sound of different objects that is thrown into the bin. The recycle bin will then sort the waste into their respective compartments.
Welcome to the AI Audio Classifier Recycle Bin Hackaday project page. All the parts necessary for this build are detailed in the "Components" section. This project is made to be reproducible, by following the "Instructions" section you should be able to build one for yourself. The Code, Gerber files, STL files, editable, PCB schematic and design are all provided in the "Files" section. All the resources in this project are fully open source so you are free to use it or modify it. I've also added some tips, hardware upgrade options, testing videos, and a case study discussion in the "Logs" section so you can learn more about this project.
Contest Entry Video
3D CAD hardware model
PCB Design (New)
Electronic Connections System Diagram (New version, with upgrades)
IoT Cloud System Diagram
Electronic Connections System Diagram (Old version, base unit)
Concept Sketch
Project specifications:
Inference Microcontroller: Arduino Pro Nicla Voice or Seeed Studio Xiao nRF52840 Sense
Actuator Microcontroller: Arduino Pro Portenta C33
Power:
Input voltage: 12V DC (3s LiPo)
Peak: 5.3 W
Build materials:
20% Acrylic
20% 3D printed PLA
55% Aluminium
5% Others
Actuators:
Rotating base: Stepper motor 17HS3401
Trapdoor: Hobby servo motor DS3225
Software:
Arduino IDE (C++)
Edge Impulse Studio
Open Source Licenses:
Hardware license: Attribution-ShareAlike 4.0 International (CC BY-SA 4.0)
Software license: Apache-2.0
Bill of Materials for 1 unit (base model):
Keep in mind that this does not include customs fee and shipping fees because it will be different depending on where you are located. This Bill of Materials does not include upgrades; with a custom PCB + Portenta C33 + Nicla Voice + other small upgrades, the cost of 1 unit may go up to USD 371.
Standard Tesselated Geometry - 144.03 kB - 10/10/2023 at 13:43
Download
Standard Tesselated Geometry - 48.42 kB - 10/10/2023 at 13:42
Download
Standard Tesselated Geometry - 133.09 kB - 10/10/2023 at 13:42
Download
Standard Tesselated Geometry - 70.79 kB - 10/10/2023 at 13:42
Download
Standard Tesselated Geometry - 52.62 kB - 10/10/2023 at 13:42
Download
View all 38 files
  • 4 × 550mm 2020 aluminium profile
  • 12 × 290mm 2020 aluminium profile
  • 28 × 90º angle bracket
  • 69 × M5 T-nut
  • 69 × M5 8mm bolt
View all 27 components
  • Portable Demonstration Device for Supercon 2023
    Samuel Alexander11/03/2023 at 15:02 0 comments
    I'll be attending Hackaday's Superconference this year! As much as I wanted to bring the AI Audio Classifier Recycle Bin to the Supercon, it is very impractical to do so. So, I have prepared a small device to demonstrate how the AI Recycle Bin works. This way I don't have to carry to bin with me on a 9000+ Miles trip to Pasadena from Surabaya.
    By the way, the two holes can be attached to a lanyard, so does it mean this device counts as a Supercon badge..?
  • Arduino Cloud Integration (AI + IoT for Smart & Sustainable City)
    Samuel Alexander10/10/2023 at 08:33 0 comments
    The Arduino Portenta C33 is Arduino Cloud compatible. By using Arduino Cloud we can make the AI Audio Classifier Recycle Bin IoT enabled. The benefit is we can create a network of Smart Bins that can be deployed in an urban park environment or another public open space. We can monitor that number of items in each compartment by counting the number of sound each item makes, once the compartment is full we can create an alert so that we can collect the item.
    For the purpose of testing the Arduino IoT cloud I'm using an Arduino UNO R4 Wifi first before deploying the code into the Portenta C33. This is just to test and see how everything goes before moving the code into the main hardware for this project.
    Once ready to be deployed to the Portenta C33, we can connect the WiFi antenna to make sure better and stable wifi connection.
  • Tuning DSP Parameters (simple trick to improve accuracy, decrease inference time and decrease memory usage)
    Samuel Alexander10/09/2023 at 13:10 0 comments
    In the Edge Impulse DSP (Digital Signal Processing) parameter tuning we can see the Mel energy levels and FFT Bin weighting. From here we can adjust and optimize the parameters to lower the memory usage and processing time (DSP + Inference time).
    The first step is to adjust the noise floor until the highest Mel energy (red) and lowest Mel energy (blue) becomes visible. I have settled with -35 dB (Initially it was set to -55 dB.
    From the diagram above we can see that there is not much pattern under 240 Hz frequency for all four different objects. So we can set the Lowest band edge to 240 Hz.
    The benefit of doing this is we can eliminate wind noise almost entirely because the signal energy of wind noise is typically concentrated below 300 Hz. Setting the lowest band edge to 240 Hz will also filter out Humming noises before we use the data for inferencing.
  • Inference on the Arduino Nicla Voice
    Samuel Alexander10/09/2023 at 07:42 0 comments
    This log will discuss how to use the Arduino Nicla Voice as the inference microcontroller board. The Nicla Voice features an NDP120™, which is an ultra-low powered and special-purpose deep-learning processor. Since this project is battery powered and will require the device to be always-on, this board makes it a really good use case. The board also features the Nordic nRF52832 which we will program via the Arduino IDE to send the inference results to the Actuator controller board (Portenta C33) via I2C using the ESLOV cable.
    The .stl and editable CAD project files for the case can be downloaded in the "Files" section in this project, the .ino code can also be found there.
    Just like the Seeed Studio nRF52840 Sense, the Nicla Voice also has a snap-fit case that enable us to mount the device to the acrylic "pyramid sink". Between the board and the top case there is a thin sheet of foam to filter unwanted wind noise and also protect the Nicla Voice from dirt and moisture.
    My Edge Impulse Project for the Nicla Voice: https://studio.edgeimpulse.com/studio/286429
    The steps for creating the AI Audio classifier model for the Nicla Voice using Edge Impulse is a little bit different than when using the Nano 33 BLE Sense and Xiao nRF52840 Sense because the Nicla Voice must use a Syntiant compatible pre-processing blocks.
    In the "Syntiant" parameters tab features extractor change to log-bin (NDP120/200).
    For the model parameters, I found that 300 cycles with 0.000025 learning rate give the best accuracy and lowest Loss value.
    In the deployment tab click "Find posterior parameters" this is special for the Nicla Voice, since we want to ignore unknown/noise we can uncheck "z_openset". The way it works is very similar to wake word detection for virtual assistant in our smartphones or smart-home speakers, the difference is instead of saying "siri", "ok Google", or "Alexa" the event will be initiated when the collision sound of bottle, can, paper, or pong is detected.
    After the Posterior parameters have been configured, click build model. The model will start building and will be automatically downloaded when it is done. Once done, flash the firmware, upload the Arduino code, mount the device on the AI Audio Recycle Bin and then everything will be ready to go!
  • Inference on the Seeed Studio XIAO nRF52840 Sense
    Samuel Alexander10/08/2023 at 15:47 0 comments
    I've tested different microcontrollers for running the Audio Classifier inference (and DSP). The project initially uses the Arduino Nano 33 BLE Sense for inferencing and Actuator controls. Since now I have upgraded the PCB to include an additional microcontroller for driving actuators, there is more flexibility to switch between different microcontrollers for running inference.
    In this log I will discuss about using the Seeed Studio Xiao nRF52840 sense (In the next log I will focus on the Arduino Nicla Voice). Since the Xiao nRF52840 Sense dev-board uses the same nRF52840 with the Arduino Nano 33 BLE Sense, the same Arduino code can be reusable without making any changes.
    My Edge Impulse Project for the Seeed Studio Xiao nRF52840 Sense: https://studio.edgeimpulse.com/public/289422/latest
    The difference between this Edge Impulse project and the original one is the data acquisition for this one was using the Xiao nRF52840 Sense. Technically the original one should work, but I just redo the process since now I'm using the filter foam and case, so the audio sample can be a little bit different.
    The 3D printed case is designed very similarly compared to the case for the Nicla Voice, the difference is on the hole placement for the microphone, the cutout for the built-in LED indicator, and the cutout on the bottom for the header pin layout. Between the top case and the Xiao nRF52840 Sense I placed a small sheet of foam to filter wind noise and other unwanted noises.
    Female header pins soldered to female ESLOV connector is used for connecting the Xiao nRF52840 Sense to the actuator microcontroller. These two microcontrollers will communicate via I2C.
    The inference microcontroller is hot swappable, in this case I'm swapping the inference microcontroller from the previously connected Nicla Voice to the Xiao nRF52840 Sense.
  • CAD 3D Model using Fusion 360
    Samuel Alexander10/08/2023 at 09:28 0 comments
    Just like the PCB and codes, all the 3D files are available in the "Files" section both as the .STL file ready to be 3D printed and also as the Fusion 360 project files, so you can modify or add more stuff from my design based on what you need.
    This log will focus on discussing some of the design decisions that I've made and some manufacturing techniques that I've used throughout this build.
    By simply adding one layer of extrusion, we can complete the print without any support materials, this is called sacrificial bridge. After finished printing, the "bridge" can be trimmed using scissors or cutting pliers.
    All of the 3D printed parts are mounted to the aluminium extrusion frame using M5 bolt and T-Nut.
    The PCB design from KiCAD can be exported as a .STEP file which can be imported to the Fusion 360 project file. This will make it easier to create the mounting plate to the aluminium extrusion frame.
  • PCB Upgrades
    Samuel Alexander10/08/2023 at 07:14 0 comments
    The initial version of the AI Audio Classifier Recycle Bin project only uses a breakout PCB stepper driver. The motor driver and the Audio Classifier model inference are both run using a single microcontroller (Arduino Nano BLE Sense).
    This upgrade offloads the stepper motor, servo motor, and IoT connectivity, so the main microcontroller just run the audio classifier inference and the result will be sent to the microcontroller that is onboard the PCB. All the manufacturing (gerber) files and KiCAD design files are included in the "Files" section of the project page.
    This new PCB also includes a buck converter, to supply 5V for both microcontrollers from a 3S LiPo battery. 12V from the battery is used for powering the stepper motors through the TMC2208 stepper driver.
    The design allows for switching to different microcontroller dev boards in the Arduino MKR and Portenta family, because they use a similar styled pinout pins. In this case, I'm using the Arduino Portenta C33 because we will use internet connectivity through WiFi. Here are some other options you can choose from:
    Arduino MKR WiFi 1010 or Arduino Portenta C33 for WiFi
    Arduino MKR WAN 1310 for LoRaWAN
    Arduino MKR GSM 1400 for GSM Cellular
  • Potential Implementation for Industrial Scale Waste Management Facilities
    Samuel Alexander10/07/2023 at 17:19 0 comments
    Waste management in industrial scale facilities is a complex task due to the diverse and large volumes of materials generated. The AI Audio Classifier can be implemented as a sustainable solution for this problem.
    Given a set of waste with materials that produce different sounds, the AI Audio Classifier excels in efficient waste sorting and recycling. It identifies materials based on the unique sounds they produce upon disposal, optimizing recycling efforts and diverting waste from landfills.
    Each waste sorting facility can handle different types of waste objects, the Audio Classifier can be tuned and programmed specifically to recognize hazardous waste sounds, the system enhances safety and ensures compliance with disposal regulations, reducing risks of accidents and contamination. Precise sorting minimizes contamination risks, guaranteeing cleaner and safer waste disposal. The technology aids compliance by ensuring waste materials are disposed of in accordance with legal mandates, reducing non-compliance risks.
    The bin can offer real-time fill-level data for efficient waste collection scheduling, reducing operational disruptions, this can be done by summing the quantity of sound window for each object type or placing an additional sensor.
    The AI Audio Classifier Recycle Bin if implemented properly at an industrial scale, could be a useful solution for the waste management management problem with its automation, precision, and efficiency. It promotes responsible waste management and sustainability while reducing operational costs.
  • Comparing Audio Classification vs. Image Classification Models for Waste Sorting
    Samuel Alexander10/02/2023 at 17:44 0 comments
    The challenges posed by the ever-increasing volume of waste require innovative solutions that are not only efficient but also cost effective and environmentally friendly. Modern industrial sorting facilities commonly uses AI Image Classification model, but this solution is not effective for waste management due to its high computing requirements, expensive hardware, and energy intensive process. One solution to this problem is the AI Audio Classifier Recycle Bin. This log will explore the benefits of using Edge AI Audio Classification model compared to a more traditional image classification model for waste management, highlighting how this technology contributes to sustainability and a cleaner urban environment.
    1. Cost effectiveness
    Edge AI audio classification offers a cost-effective solution for waste sorting. Compared to image-based systems that require high-resolution cameras and extensive computational power, audio classification systems are often more affordable to implement and maintain.
    Let’s take an example a PDM MEMS microphone breakout board costs less than $5 (The MP34DT06JTR mic if bulk purchased as SMD Reel can cost less than $1) now compare that to a low cost camera sensor like the 2MP GC2145 which costs more than $7. If a higher resolution camera is required, the cost will increase even more.
    Since image classification inferencing requires more clock speed and memory, the hardware to support will also be more costly.
    2. Compute requirements and energy efficiency
    Edge AI audio classification offers a faster and more efficient waste sorting process compared to image classification. The technology can process and classify items in real-time as they are thrown into the bin, without the need for additional time-consuming steps like capturing and processing images. This efficiency leads to reduced wait times for users and ensures that waste is sorted swiftly and accurately. The Digital Signal Processing and inferencing time for audio is less than it is for image.
    3. Accuracy and reliability
    One of the primary advantages of using edge AI audio classification for waste sorting is its precision. Unlike image classification, which relies on visual cues, audio classification can discern subtle differences in the sounds made when objects are thrown into the bin. This precision results in a more accurate sorting process. For instance, it can differentiate between a glass bottle and a plastic bottle, even if they look similar, by analyzing the distinct sounds they produce when landing in the bin.
    Image classification relies heavily on the appearance of objects, making it susceptible to errors when items are damaged, obscured, or have ambiguous visual features. In contrast, edge AI audio classification is not affected by such limitations. It can accurately identify and sort objects based solely on the sounds they generate upon impact. This non-reliance on visual appearance ensures a reliable and consistent sorting process, regardless of the condition of the waste items.
    The AI Audio Classifier Recycle Bin, powered by edge AI audio classification, represents a significant advancement in waste management technology. Its precision, non-reliance on visual appearance, increased efficiency, and cost-effectiveness make it a compelling alternative to image-based sorting systems.
  • Engineering drawing and project specifications
    Samuel Alexander07/04/2023 at 12:07 0 comments
    Added engineering drawing and project specifications.
View all 11 project logs
  • 1
    Build the jig for data acquisition
    In order to collect sound data of the rubbish objects, we need to first build the minimal hardware necessary as shown in the below pictures, this makes sure that the collected data will be similar to the real scenario. At this stage we don't need a functional smart bin, so it is ok to just use a sticky tape to keep the trapdoor and some acrylic parts in place.
    For the aluminium build use the 550mm aluminium for the vertical profile and 290mm aluminium for horizontal profile. The inverted pyramid shaped acrylic sink can be mounted to the top four 290mm aluminium as shown below. You can tape the MCU board (Arduino Nano 33 BLE Sense) in place or use the case. All design files and parts list are included in the "Files" and "Components" tab.
  • 2
    Build the AI model using Edge Impulse
    [New update: Check out this log if you want to use Seeed Studio Xiao nRF52840 Sense]
    [New update: Check out this log if you want to use Arduino Nicla Voice]
    If you want to use my Edge Impulse project model you can access it here: https://studio.edgeimpulse.com/public/244026/latest
    If you want to build your own model, you can follow along the steps below:
    For this step you will need to sign up for an https://edgeimpulse.com/ account and then log in. To connect your MCU board to Edge Impulse, you need edge impulse CLI on your computer and then burn the Edge Impulse firmware for Arduino BLE Sense, Here is a more detailed instruction to do so: https://docs.edgeimpulse.com/docs/development-platforms/officially-supported-mcu-targets/arduino-nano-33-ble-sense
    After connected, create a new project and go to the Edge Impulse "Data acquisition" tab and start collecting audio data. Choose Device: Arduino BLE Sense, Sensor: Microphone, Frequency: 16,000Hz, Sample length: 19,000, and most importantly name the label depending on the rubbish object you want to sample.
    You can now start sampling, since each sample length is 19 seconds, you can later split it into 1 second window and adjust it to when the collision happen. Ideally you want about 60 sample of 1 second window for each rubbish objects.
    Next, go to the Impulse design tab, select create impulse and set the parameters to the screenshot below.
    Autotune parameters and generate features on the MFE tab.
    Start training on the classifier tab using default parameters (this may take a while).
  • 3
    Program your Microcontroller
    On the Edge Impulse "Deployment" tab you can configure your deployment. Choose Arduino library and click build. This will create the Edge Impulse AI model as a .zip file which you should unzip and place the unzipped folder in the Arduino "libraries" folder.
    Now you can download the .ino code in this Hackaday project's "files" tab and then upload it to your Arduino.
View all 6 instructions
wayywishh wrote 05/13/2024 at 05:05 point
hello sir
whats the use of neodymium magnet
Russell Jennings wrote 04/29/2024 at 10:14 point
This Smart Recycle Bin project by Samuel Alexander is truly innovative! It's incredible to see technology being used to tackle real-world problems like recycling confusion. The use of an AI Audio Classifier to sort waste based on collision sounds is brilliant. I recently did a project on a similar topic and found a research proposal writing service at https://essays.edubirdie.com/research-proposal-writing-service, which provided really useful insights into waste management technologies. Integrating IoT capabilities into the bins for smart city initiatives is a great idea too. Kudos to Samuel for this ingenious solution!
bezanilla1997 wrote 04/24/2024 at 14:45 point
Hi. I'm interested in purchasing one of your kits. Could you please contact me?
Adharsh CS wrote 04/19/2024 at 16:25 point
What was the wall thickness of the container, My print is failing due to the model's low thickness. Do you have any solutions for this issue?
abhiishek7 wrote 04/07/2024 at 05:49 point
hello, sir
my self Abhishek from India
required your help in our project as we took this as our final-year project
1. actual components
2. source codes
3. PCB design
4. connections diagrams
5. photos
6. how to connect components to the edge implies studio
please contact me on
following Gmail and
abhishekspawar7@gmail.com
abhishekpawar0024@gmail.com
pawarabhishek0024@gmail.com
contact as soon as possible
Component Quantity
1) DC-DC boost charger
2) Li-ion 1s 250mAh battery
3) TMC2208 stepper driver
4) Hall sensor A3144
5) 17HS3401 Stepper motor
6) DS3225 Hobby servo
7) Seeed Studio Xiao nRF52840 Sense
8) Portenta c33
filiusjacobi wrote 11/19/2023 at 12:56 point
Good day sir! Is it okay to use the REV 2 version of the Arduino Nano 33 BLE Sense? If yes, what are the problems that I will encounter since the microphone of the rev2 version and other sensors are not yet compatible with the software of edge impulse? Thank you!
123abcdc wrote 11/12/2023 at 13:13 point
室外有车声,和其他噪声怎么办,要使用到深度学习吗?机器内部的噪声如何解决
TRAN.VINH.QUANG wrote 11/11/2023 at 09:03 point
Great job! Could I translate your work to vietnamese and share to our community with original link include ?
Samuel Alexander wrote 11/11/2023 at 12:45 point
Yes definitely, that'd be wonderful!
esnake345 wrote 11/03/2023 at 05:57 point
hey samuel is it neccesary to use hall sensor for calibration
And can i buy the ai classifier board
Samuel Alexander wrote 11/03/2023 at 14:33 point
Limit switch or rotary encoder may work as well for calibration. You can download the AI Classifier Board geber files and send it to a PCB manufacturer for it to be made.
Jallson wrote 10/10/2023 at 12:45 point
Nice project. It would be very useful if it were placed in a public place and could be monitored to see whether the compartment is completely filled.
Samuel Alexander wrote 10/10/2023 at 13:46 point
Indeed! That is the goal, this project's true potential will only be realized if it can reach mass deployment.
