RF Box Bottom 11-14.stlSTL file for the bottom of the RF Faraday Cage.Standard Tesselated Geometry - 512.58 kB - 11/14/2023 at 19:43 |
RF Box Bottom 11-14 STEP.stepSTEP file for the bottom of the RF Faraday Cage.step - 65.28 kB - 11/14/2023 at 19:42 |
RF Side 1 11-14 STEP.stepSTEP file for side 1 insert in the RF Faraday Cagestep - 15.37 kB - 11/14/2023 at 19:42 |
RF Side 1 11-14.stlSTL file for side 1 insert in the RF Faraday CageStandard Tesselated Geometry - 25.67 kB - 11/14/2023 at 19:42 |
RF Side 2 11-14.stlSTL file for side 2 insert in the RF Faraday CageStandard Tesselated Geometry - 25.67 kB - 11/14/2023 at 19:42 |
RF Side 2 11-14 STEP.stepSTEP file for side 1 insert in the RF Faraday Cagestep - 15.39 kB - 11/14/2023 at 19:42 |
RF Box LED Cover (07-31 - STEP).stepSTEP file for the cover in front of the LED through hole (to prevent RF leakage)step - 11.34 kB - 08/14/2023 at 16:00 |
RF Box PD Cover (07-31 - STL).stlSTL file for the cover in front of the photodiode through hole (to prevent RF leakage)Standard Tesselated Geometry - 35.24 kB - 08/14/2023 at 16:00 |
RF Box Lid (07-31 - STEP).stepSTEP file for the lid of the RF Faraday Cage.step - 25.70 kB - 08/14/2023 at 16:00 |
RF Box PD Cover (07-31 - STEP).stepSTEP file for the cover in front of the photodiode through hole (to prevent RF leakage)step - 11.34 kB - 08/14/2023 at 16:00 |
RF Box Lid (07-31 - STL).stlSTL file for the lid of the RF Faraday Cage.Standard Tesselated Geometry - 14.54 kB - 08/14/2023 at 16:00 |
RF Box LED Cover (07-31 - STL).stlSTL file for the cover in front of the LED through hole (to prevent RF leakage)Standard Tesselated Geometry - 35.24 kB - 08/14/2023 at 16:00 |
