1Unpack your kit
Each kit comes with the following items included:
1 - Stuffed plushie
1 - 3mm red LED
1 - 3mm green LED
1 - 3mm blue LED
3 - Red wires
3 - Blue wires
2 - 499ohm resistors
1 - Battery holder
2 - CR2032 batteries
2Remove stuffing
Remove the stuffing from the plushie and set aside.
3Push LEDs through
Push each LED through the corresponding square on the top of the plushie. Be sure to support the LED legs when pushing through so they don't bend. Make sure that all LEDs are facing the same direction. Once all LEDs are through, turn the plushie inside out.
4Bend LED legs & add resistors
Bend the LED legs and wrap the resistors around the positive leg of the red and green LEDs. Bend the LED leg over to secure resistor)
5Twist red wires to positive LED leg & resistors
Twist the red wires to the resistors and the positive leg of the Blue LED, Bend in half to secure wire.
6Twist blue wires to negative LED legs
Twist the blue wires around the negative leg of the LEDs. Bend leg in half to secure the wire.
7Put battery holder wires through the hole in the pocket
Push the wires through the pocket so the wires are on the inside of the plushie and the battery holder is on the outside.
8Attach red wires to the positive wire of the battery holder
First, remove the pre-cut insulation from the ends of the battery holder wires. Gather all of the red wires together along with the positive wire of the battery holder. Twist all the wires together and bend in half.
9Wrap tape around the exposed negative LED legs and attach blue wires to the negative wire of the battery holder
Covering the LED legs and wires prevents the LEDs from shorting when you put the stuffing back in. Gather all of the blue wires together along with the negative wire of the battery holder. Twist all the wires together and bend in half.
10Wrap tape around the Negative battery holder and blue wires.
This prevents the LEDs from shorting when you put the stuffing back in.
Alpenglow Industries
TAKE MY MONIES!!11
