Standard Tesselated Geometry - 1.06 MB - 08/11/2023 at 15:34 |
TopBodsplit1.stlThis joins with TopBodySplit2, it was too large to print without warping.Standard Tesselated Geometry - 2.23 MB - 08/11/2023 at 15:34 |
Standard Tesselated Geometry - 53.51 kB - 08/11/2023 at 15:33 |
Standard Tesselated Geometry - 52.92 kB - 08/11/2023 at 15:33 |
Standard Tesselated Geometry - 119.22 kB - 08/11/2023 at 15:33 |
Standard Tesselated Geometry - 21.57 kB - 08/11/2023 at 15:33 |
Base_4_001.stlThis needs to be split into separate parts, the inside piece should be printed with honeycomb infill at 30% with no top or bottom layer to create a vent.Standard Tesselated Geometry - 1.67 MB - 08/11/2023 at 15:31 |
Standard Tesselated Geometry - 27.62 kB - 08/11/2023 at 15:31 |
Standard Tesselated Geometry - 65.65 kB - 08/11/2023 at 15:31 |
Standard Tesselated Geometry - 1022.09 kB - 08/11/2023 at 15:28 |
Standard Tesselated Geometry - 435.83 kB - 08/11/2023 at 15:28 |
Standard Tesselated Geometry - 141.03 kB - 08/11/2023 at 15:28 |
grill.stlGeneric Grill TemplateStandard Tesselated Geometry - 192.86 kB - 08/11/2023 at 15:28 |
grill2.stlGrill with mounting points for GPIO Header and a Pi CamThis needs to be split into separate parts, the inside piece should be printed with honeycomb infill at 30% with no top or bottom layer to create a vent. Standard Tesselated Geometry - 193.59 kB - 08/11/2023 at 15:28 |
block.stlA spacer I glued in front of the USB and HDMI ports as the rail hits them when fully extended. Eventually I'll add these directly inside the topbod stl but didn't want to reprint it all again.Standard Tesselated Geometry - 1.45 kB - 08/11/2023 at 15:28 |
