ESC/Servo Test
A project log for Felini - Revolutionary Pocket-Sized Electronic Lab
Extremely affordable pocket-friendly, designed to provide a wide range of hardware testing and debugging functions in a compact and low-cost
chu-tien-thinh-obitvnChu Tien Thinh (obitvn) 08/21/2023 at 08:030 Comments
The tool that Felini will replace in this log update is an RC ESC/Servo tester. Servos require a pulse frequency of 50Hz, with active-high time ranging from 0.5ms to 2.5ms.
If you don't want or don't have a blue-colored Servo tester like the one in the picture, you will need to invest some time in coding and generating PWM pulses... just to set the rotation angle or check if the servo is actually functioning. This is unnecessary when you have Felini.
