• Wired rpi0w for GFX again
    Franck GALLIAT • 12/01/2017 at 06:23 • 0 comments
    Hi,
    I reconnected my rpi0w to the system, for HDMI output (@ this time it does VGAT emulation) may soon I'll make a simple GUI instead (with simple feedbacks as it is now connected on a dedicated Serial port & no more on same port as Keyboard !)
  • Just added X11 VGAText emulation
    Franck GALLIAT • 11/24/2017 at 17:24 • 0 comments
    Hi, today I have a working version of VGAText output emulation for your *nux computer,
    It emulates for both sides (Teensy & RPI) a serial port communication to render as real VGAT interface on your Desktop.
  • Xts-uBASIC can now run on your computer !
    Franck GALLIAT • 11/22/2017 at 08:37 • 0 comments
    Since today : it's now possible to test BASIC directly on a g++/SDL2/ncurses computer
    g++ build script is available on github
  • It's alive !!!!
    Franck GALLIAT • 11/15/2017 at 16:24 • 0 comments
  • Begins of 'flat' mother board
    Franck GALLIAT • 11/15/2017 at 16:23 • 0 comments
    Main module + DFPlayer MP3 + VGAText + USB Hub as DBUG & PWR supply
  • Starting an enclosure for the system
    Franck GALLIAT • 11/14/2017 at 11:50 • 0 comments
    Hi, I started to make a box for my computer system....
    I decided to re-use an old MO5 case, which I emptied & added hinges.
    I started to separate the OLED Display & button, then glued an android tablet USB flat keyboard :
    So it looks like that for now.
  • MP3 Sound Card added
    Franck GALLIAT • 11/13/2017 at 11:52 • 0 comments
    Hi, I recently added a DFPlayer mp3 module to act as a sound card, this looks like this :
  • VGA Text replacement
    Franck GALLIAT • 04/02/2017 at 17:06 • 0 comments
    Hi, today I nearly achived the Simple VGAText Serial ouput (100x50 chars - text ONLY interface) replacement by re-using a Raspberry PI Zero + Java + FrameBuffer.
    It does actually run an emulation of the VGAText micro-code (receiving text & escaped commands from the Serial Port) to make a Pseudo text-based UI.
    It boots & start the program in 14sec from strict powering up time (8sec from linux starts booting).
    The cons : It does not starts instantanatly,
    the pros : It can be use on ANY HDMI TV or Computer Monitor even with too high resolution, later it will be able to receive some GFX commmands, the render code is (on-board) modifiable, Keyboard reading will replace the HobbyTronics USB Host (keyb preprogrammed) board, & it costs nearly as same as HobbyTronics VGA TEXT board...
    I know, It could replace the whole system, but I keep my MCU (teensy3.6) board to do the main Unit... (just for personal fun ! )
    to follow ...
  • The system is growing up...
    Franck GALLIAT • 03/05/2017 at 13:51 • 0 comments
    ADDED Wifi + additional POWER SUPPLY Boards (+ still VGA Board) (allows me to read web RSS Feed)
  • My Wifi ecosystem
    Franck GALLIAT • 03/05/2017 at 13:48 • 0 comments
    WebContent minified by a cloud server // ESP8266 packet re-formed by AT328P
    to provide String Arrays to my BASIC
