Instructions.pdfFull instructions to get you from parts, components and 3D printer filament to a working RC Snowplow.application/pdf - 10.73 MB - 08/09/2023 at 23:57 |
snowbyte.inoArduino code for the SnowByte. The code is also available at https://github.com/cele9999/RCSnowplow/ .ino - 6.04 kB - 09/07/2023 at 20:33 |
Standard Tesselated Geometry - 46.47 kB - 08/24/2023 at 23:18 |
Standard Tesselated Geometry - 1.27 MB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 305.45 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 643.15 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 305.94 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 25.08 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 11.61 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 3.79 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 32.70 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 34.26 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 8.87 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 3.01 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 13.17 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 7.89 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 32.80 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 1.45 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 28.30 kB - 08/09/2023 at 22:00 |
Standard Tesselated Geometry - 31.53 kB - 08/09/2023 at 22:00 |
