Hackaday.io Hackaday.io
Sign up Log in
LoRa MailBox Guard
The Mailbox Guard is a device that detects when a new letter or package has been delivered to your mailbox using a PIR sensor and door reed
dmDM
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
922
2
7
6
Team (1)
  • dmDM
Join this project's team
  • MailBox Guard
hardware
completed project
lora MAILBOX home assistant attiny pcb diy
Related lists
Build
Summary
kkkkkkkkk
good project indeed
This project was created on 08/16/2023 and last updated 3 years ago.
Description
Hey guys, I've finally wrapped up my NEW LoRa Mailbox/PIR/ReedSwitch project. The project is completely open-source you can find the GitHub link in the video description. I hope someone besides me will find this project interesting 😊 Enjoy! The Mailbox Guard is a device that detects when a new letter or package has been delivered to your mailbox using a PIR sensor and door reed switch. It can send a signal to your LoRa gateway, then the gateway sends a message via WiFi to Home Assistant "MQTT" or to WhatsApp allowing you to receive notifications directly into your phone. Or you can use it offline, the gateway display will show the number of letters received, Battery status, and signal strength.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
nerdu wrote 08/18/2023 at 06:59 • point
nice, but why not change it to https://meshtastic.org/ or https://reticulum.network/ mesh lora.
This will work outside as node.
DM wrote 08/19/2023 at 15:04 • point
Yes, it can be done but, I'm a home assistant user, and never worked on LoRaWAN.
Connect the project to your laptop or phone and then chat between the devices without internet or SMS using just LoRa. Serial terminal based
Project Owner Contributor
LoRa Messenger for two devices for distance up to
akarshagarwal98akarshagarwal98
A Security Device perfect for your home or vaults
Home Security
4d-makers4D Makers
Breathing new life into an aging beast.
DuinoDCX
lasse-lukkariLasse Lukkari
Learn how to build a gas detector using an ESP32 and an MQ-2 sensor, featuring an email alert system through a PHP server.
ESP32 & MQ2 GAZ DETECTION E.MAIL
emericbEmericB
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "LoRa MailBox Guard", please tell us the reason.
Send message
Remove Member
