OSO-BOOK-B1.pdfPDF of the Open Book schematic, as submitted for the Hackaday Prize.Adobe Portable Document Format - 652.29 kB - 10/08/2023 at 04:28 |
OSO-BOOK-B1-01.zipGerber files for rev 01 of the Open Book, as submitted for the Hackaday Prize.Zip Archive - 3.95 MB - 10/08/2023 at 03:47 |
OSO-BOOK-B1.csvBOM for rev 01 of the Open Book, as submitted for the Hackaday Prize. Specific part numbers are mentioned in the “Value” column; generic passives include just the component value and spec since the specific part I used doesn't really matter. Check the “Footprint” and “Notes” column to make sure you're getting the right stuff.Comma-Separated Values - 2.90 kB - 10/08/2023 at 05:18 |
Open Book - Sprint 5.scadOpenSCAD sources for the Open Book enclosure as of the Hackaday Prize submission. Designed for FDM printing. Some options may not be fully implemented. NOTE: This design requires that you use either metal M2.5 screws (to bite into the plastic) or an M2.5 tap wrench if you plan to use nylon screws.scad - 11.47 kB - 10/08/2023 at 04:31 |
Open Book - Sprint 5 Frontplate.stlSTL file for the WIP frontplate, generated from the OpenSCAD sources above. Designed for FDM printing; the fit may not be as good with other fabrication processes.Standard Tesselated Geometry - 155.16 kB - 10/08/2023 at 04:43 |
Open Book - Sprint 5 Backplate.stlSTL file for the WIP backplate, generated from the OpenSCAD sources above. Designed for FDM printing; the fit may not be as good with other fabrication processes.Standard Tesselated Geometry - 133.48 kB - 10/08/2023 at 04:43 |
