• Architecture: Introduction and Stakeholders
    Andrei Gramakova day ago 0 comments
    Here are the first three chapters of my arc42-based architecture documentation. Next time we are doing the architecture constrains and maybe the system scope. It is necessary if I want to make it right, but if you are bored, please wait for 2–3 posts, when we will start describing the system structure 🙂
    Introduction and Goals
    This project is an effort of establishing a development workflow via practical product development.
    There are two main requirements for the project:
    • The product should be a working and entertaining for a cat autonomous toy.
    • Components, processes and libraries of the project must be developed to be reusable in other projects.
    The project is based on the following principles:
    • Architecture-oriented
      • Develop the right architecture using architectural best practices
    • Result-oriented and minimalistic
      • Progress over perfection
    • Integration-oriented
      • Reusing existing libraries, projects, etc. Minimum development of individual pieces
    • Reusable in my other projects
      • It should be done automatically with a good architecture. But I want to make several special decisions to make the project easy to transfer to my another robotic project.
    Quality Goals
    NQualityMotivation
    1Cat FriendlinessThe product should be interesting and attractive for a cat
    2SafetyThe product should be safe for pets, it should not harm the pet in any way
    3Development ReusabilityThe project components should be easy to reuse in other projects. Especially in my own projects
    Stakeholders
    Role/NameExpectations
    Cats (especially Bastet)Cats should get a simple, funny toy that is able to entertain them.
    DevelopersDevelopers must get a polished, transparent quality product that can be reused or valuable from the education point of view
    Andrei GramakovI suppose to do two things at once: 1. improve my architect skills, 2. move my another enormously big robotic project.
    Potential employers of Andrei GramakovShould get an illustrative entry in my portfolio to better understand my skills and experience.
  • Selecting the Tools
    Andrei Gramakov4 days ago 0 comments
    There are some decisions to make. These decisions are basically our tools preparation. Let’s start from the frameworks
    Frameworks
    Architecture frameworks:
    • arc42 - describes the structure, tools are up to implementors, can be used with other frameworks
    • 4+1 - Generic and can be not enough for complex systems, can be used with other frameworks
    • C4 model - lacking the structure, often used with arc42
    • UML - SW oriented language. No documentation structure can be used with other frameworks. But as a visual framework it is very developed and widely used.
    • RM-ODP - for Distributed Processing. It seems not very suitable for the project
    • Systems Modeling Language (SysML) - extension of UML to support not only SW systems. Should be
    • TOGAF - popular framework for enterprise architecture. To be honest, looks too complicated for me and my project.
    • ArchiMate - a visual addition to TOGAF. These folks are super developed and have a very steep learning curve, so I will skip them for this time.
    My choice is:
    🎉 arc42 + SysML 🎉
    Having them two, I will have a text guidance + visual guidance. Also, I already have a quite comprehensive experience with UML, so it should help the process.
    Subjects of Development
    Now let’s consider what we are going to create. In the book Clean Architecture, the author provides a picture like this to illustrate what is the clean architecture:
    We should start from defining the core and delay the rest decision as long as possible. The outer layer should be dependent on the inner one.
    Next Step
    Next time, I will define some basic entities we will be working with and will describe the first chapters of the arc42 template, such as:
    1. Introduction and Goals
    2. Constraints
    3. Context and Scope
    4. Solution Strategy
  • Architecture of Architecture
    Andrei Gramakov09/14/2023 at 21:37 0 comments
    Okay, to build an architecture I need some model or workflow. I could come up with something, but it contradicts to one of the project principles - “integration first”. I don’t want to reinvent new things if they are already invented. So let’s see what we have…
    Also, there are several nice articles for orientation in all this ocean
    I need some time to think about it, so the next step is postponed for the next time… But the next time we will have the guidance (I’ll explain my choice) and we will do some pretty stuff!
  • LeOn, a Cat Companion. Architecture First.
    Andrei Gramakov09/10/2023 at 19:56 0 comments
    With this post, I start my new robotic project. This project will have several important features:
    • Integration-oriented.
    What is the project about?
    It is a cat companion. A simple robot that can move around, avoid big obstacles and move a stick for playing with a cat.
    What is the first step?
    I’m starting with the architecture development. I will try to make the most abstract decisions first, leaving the implementation details to the very end.
    The first step is development of the use cases. Basically, there are 3 actors for this robot - a cat, a cat owner, and me, a robotic developer. As a developer, It is important for me to have a moving platform (legs, wheels, etc.) reusable by other projects, so it is also reflected in my use case diagram:
    That is it for now. Next time we will probably define the system requirements based on each use case.
