Key Features:
- ZIF Socket Integration: This specialized protoboard is engineered to securely seat ZIF sockets, providing ample space for your components to fit snugly and securely.
- Dual Voltage Bus Lines: With dedicated voltage bus lines on both the left and right sides, this protoboard allows for easy power distribution, ensuring optimal performance and stability in your circuits.
- Labeled Columns for Enhanced Organization:
- Columns A-E on the left
- Columns F-J on the right
These labeled columns offer a structured layout, facilitating clear and organized circuit design.
Why Choose the 28-Pin ZIF Protoboard?
- Effortless Integration: Designed to seamlessly integrate with ZIF components, this protoboard eliminates the hassle of spacing issues, allowing for smooth and secure connections.
- Enhanced Power Distribution: The dual voltage bus lines provide flexibility in powering different sections of your circuit, guaranteeing smooth operation and reliability.
- Streamlined Organization: With labeled columns on both sides, you can plan and execute your circuit designs with precision and clarity.
Bits4Bots
Neil Mundt
kamalkedin123
