Why Choose the 28-Pin SOP Protoboard?
- Effortless Integration: Designed to seamlessly integrate SOP components, this board eliminates the frustration of cramped spaces, allowing you to focus on creating and innovating.
- Enhanced Power Distribution: The dual voltage bus lines give you the flexibility to power various sections of your circuit, ensuring optimal performance and stability.
- Streamlined Organization: With labeled columns on both sides, you can easily plan and execute your circuit designs with precision and clarity.
Take Your Projects to the Next Level
Whether you're a seasoned electronics enthusiast or just starting out, the 28-Pin SOP Protoboard is a must-have tool in your arsenal. Experience the freedom to explore, test, and innovate without the limitations of standard breadboards.
Get 70 (14 x 5) component terminals, compared to only (14 x 1) on a standard breadboard when populated with the SOP socket.
Bits4Bots
Tim Savage
Bil Herd
Neil Mundt
We have a design for ZIF sockets coming soon. How would you use these little protoboards?
