Breaking down this project there are a few things that I need to research.
There are some obvious things that make a Fendt look like it does.
The most obvious are the white cab top, and the red hubs.
I expect that I will be able to dig up some wheel hubs that are red or can be made to be so.
The white cab top I currently plan to make an assembly out of metal and 3d printed ABS. I will design it so that the mirror and lights that are bracketing the can can be mounted. Since my Tacoma doesn't have blind spot detection I will work the electronics for that into these mirrors.
Not sure what to do about the front bumper presently but for the grill I will like again, 3D print in sections in ABS.
The simplest place to start with is the shift knob and center console. I want to make it look like the joystick in the Fendt.
So the first thing I am going to do is adapt my current center console setup
The Toyota shift knob is threaded with a M8*1.25" threaded insert so I will start with that and insert it into the 3d printed part.
For the front I will probably start with something like this grill from Taco Clout. It's made out of ABS so extending it with 3d printed ABS ought to be fine. Plus it has an easy spot for the FENDT Logo to go.
Caleb Eastman
Don Juan De Pyro
Bobby Feather
Giovanni Leal
