Trying new design with Quicc connector and led
12/08/2023 at 06:49 • 0 commentsThis may be a bad idea placing i2c connector near the wifi antenna plug, but this is the reason I went for the non-pcb antenna. I will Have to order test boards to check how well this design works.
Welcome post
11/15/2023 at 06:31 • 0 commentsHello!
This is the initial post for the Dendrite-S3!
Background:
This is the Robot Driver Board for the Lab-Rat a series of robot kits as a part of the parent project: Behavioral Robotics.
At this point, the board is already up for sale on Tindie, but is can still be improved upon. The board is currently being sold as a robotics development board, but will be the driver for the first series of kits as they roll out. I will post other components on my page in the future.
Some things that still need to be done for this board:
- Possible power LED
- Firmware
- Pinout on bottom silkscreen
- Possible USB power cutoff using switch
- Upload PCB files to Github
- Documentation on ReadtheDocs
- Profit!
