1Order a LDC1101EVM and a LQW2UAS4R7J00
I know it is expensive and understand it is currently only feasible if you are working at some university or company.
2Solder the coil on the back of the LDC1101EVM.
Be sure to solder it under a 90 degree angle.
3Make a fixture to mount the LDC1101EVM on your 3D printer bed
You can use my design for the diabase H-series as a reference.
4Connect the LDC1101EVM and the printer to your computer using USB
5Use the provided GUI to calibrate the printer
The software is written for a printer running a DUET wifi that communicates using gcode. It might work on other printers that are controlled using gcode, but realistically you probably have to tweak the code a bit to make it work with your printer.
Martijn Schouten
