Cat-to-Cat is a paired set of two cat toys for long distance friends and their felines. Either toy is activated whenever the other cat has started to play! If toy A is rattled with by a cat in Argentina.... toy B's wand will begin to move by a motor and catch the attention of its owner's cat in Norway! The action bounces back and forth between cats as they play. You and your long distance BFF will delight as your cats both share in each other’s fun throughout the day.
