ESPBell-MAX and LITE Intercom / Doorbell IoT modul
No more missed doorbell rings
dmDM
No more missed doorbell rings while working with headphones! Meet ESPBell-Max and ESPBell-Lite Smart intercom and doorbell IoT modules. These devices seamlessly integrate with Home Assistant and ESPHome, providing interactive notifications 🔔 that keep you updated about visitors. And the cherry on top? You can directly open the door from the notification - simply tap "Open Door" or "Ignore" to dismiss the alert.
Two version is available ESPBell-MAX and LITE, Max is battery-powered, and LITE requires a power supply.
  • 1
    Step 1
    To make the building process easier, I have provided an interactive HTML ibom file to help with component placement and polarity.
View all instructions
DM wrote 12/15/2023 at 19:58 point
ESPbell is an open-source project so all files for PCB assembly and code are available on GitHub
