First of all, I’d like to note that my soldering iron is currently nonfunctional, so all the wiring is just tied together, so I used a magnetic antenna base to connect to the SDR.
Also, don’t get hot glue on plastic foam. The whole house filled with smelly fumes that burnt every orifice on my face.
This has not been tested yet due to Christmas shopping. Once it has been tested, an update will be made. There may even be a second attempt if this is actually trash (which, it probably is). I’d like all comments based on how I can improve it with the trash I currently have.
Software I use:
- SDR++
- SatDump
- N2YO.com
