vee_channel_vibrator_mount_large_v2.stl
larger mount to take a 280 motor
Standard Tesselated Geometry - 104.96 kB - 07/06/2025 at 13:40
Download
controller_case-Rear.stl
Case (rear) for the screen
Standard Tesselated Geometry - 727.43 kB - 07/06/2025 at 13:39
Download
controller_case-Front.stl
Case (front) for the screen
Standard Tesselated Geometry - 765.32 kB - 07/06/2025 at 13:39
Download
drum_feeder_scoop_v3.stl
latest (smaller) scoop design
Standard Tesselated Geometry - 4.57 kB - 07/06/2025 at 13:38
Download
PDQ_ILI9341_config.h
header file to accompany Lego_display.ino
h - 2.40 kB - 07/06/2025 at 13:38
Download
Lego_display.ino
Arduino Nano C source for the microcontroller that runs the touchscreen
ino - 16.77 kB - 07/06/2025 at 13:38
Download
Lego.ino
Arduino Nano C source for the microcontroller on the machine
ino - 13.72 kB - 07/06/2025 at 13:37
Download
off_centre_mass.stl
Standard Tesselated Geometry - 953.79 kB - 06/17/2024 at 19:51
Download
Vee_channel_end_scoop.stl
Standard Tesselated Geometry - 810.63 kB - 06/17/2024 at 19:51
Download
tube_spindle_mount.stl
Standard Tesselated Geometry - 314.14 kB - 06/17/2024 at 19:51
Download
sensor_housing.stl
Standard Tesselated Geometry - 715.12 kB - 06/17/2024 at 19:51
Download
vibe_feeder_end_bracket.stl
Standard Tesselated Geometry - 492.07 kB - 06/17/2024 at 19:51
Download
65mm_pipe_flange_v2.stl
Standard Tesselated Geometry - 382.99 kB - 06/17/2024 at 19:51
Download
photodiode_tube.stl
Standard Tesselated Geometry - 82.60 kB - 06/17/2024 at 19:51
Download
vee_channel_rigid_mount.stl
Standard Tesselated Geometry - 47.15 kB - 06/17/2024 at 19:51
Download
40mm_pipe_clamp.stl
Standard Tesselated Geometry - 135.04 kB - 06/17/2024 at 19:51
Download
roller_bracket.stl
Standard Tesselated Geometry - 217.86 kB - 06/17/2024 at 19:51
Download
motor_mount_upper.stl
Standard Tesselated Geometry - 198.91 kB - 06/17/2024 at 19:51
Download
Vee_channel_hood.stl
Standard Tesselated Geometry - 3.01 kB - 06/17/2024 at 19:51
Download
motor_mount_lower.stl
Standard Tesselated Geometry - 85.82 kB - 06/17/2024 at 19:51
Download
