Final_avec_micro.inoThis is the final code including all sensors and LEDino - 2.87 kB - 01/12/2024 at 13:04 |
led.inoInitial code for Switching LEDino - 1.13 kB - 01/11/2024 at 23:35 |
sound.inoMeasuring and Printing the Sound Levelino - 365.00 bytes - 01/11/2024 at 23:35 |
delay.inoModified Code with Small Delayino - 1.37 kB - 01/11/2024 at 23:35 |
counting_zerocrossing.inoFinal Code with Counting Zero-crossingino - 2.91 kB - 01/11/2024 at 23:35 |
thunder (thickness_0.5mm).stl3D print file for thunder shape. (Thickness is being specified)Standard Tesselated Geometry - 34.85 kB - 01/11/2024 at 23:26 |
box v8.dxfBox shape for our laser cut.AutoCAD DXF - 1.73 MB - 01/11/2024 at 23:25 |
