Nixie Clock
The second Nixie Tube Clock i made so far :)
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This Nixie Tube Clock is made out of 4 pieces IN-18 Nixie Tubes, driven by 5 TPIC6B595 High Voltage Shift Registers.
The microcontroller used in this project is an Atmel AT-mega88.
The Voltage input is 24V and for the Tubes a little Boost converter is used to step the input voltage up to 180V.
The Power drawn by the whole circuit is about 6Watts.
