Source code:
https://github.com/ktakiman/mathquiz (main program)
https://github.com/ktakiman/eepromprogrammer (EEPROM programmer)
Details:
The code which interfaces with Nokia 5110 LCD was written from ground up. Both math questions and music data are stored in external EEPROM, allowing me to create a new set of questions or change music without re-programming the MCU. The current stage is stored in the ATMega's internal EEPROM so the user continues from the stage that she was on last time. Level Shifter chip was used to convert 5V output pins of ATMega to 3V input pins for the LCD monitor.
The data in EEPROM needs to be in a specific binary format which is described down below. I wrote a simple Windows Form app (WIndows only... lame, I know, sorry...) to create this binary data from text files which define math questions and music data. This tool can also program EEPROM through USB/FTDI cable, which is connected to the EEPROM programmer which is made with ATtiny 4313. All source codes are available in github.
EEPROM data format:
Data are divided into 4 sections:
Contents | Size |
Address table section | 6 bytes |
Question data section | depends on number of questions |
Sound data section | depends on number of songs and length of each song |
Reward key section | 4 bytes |
Address table section specifies the starting address of the three following sections:
Contents | Size |
Starting address of question data section (always 0x0006) |
2 bytes |
Starting address of sound data section |
2 bytes |
Starting address of reward key section | 2 bytes |
Question data section is just a list of questions preceded by the stage count and number of questions in each stage:
Contents | Size |
Number of stages ( = nST ) | 1 byte |
Number of questions per stage ( = nQPS ) | 1 byte |
Questions: |
5 * nST * nQPS bytes |
Each Question consists of:
Contents | Size |
First number | 2 bytes |
Second number | 2 bytes |
Operand ( '+' or '-' or '*' or '/' ) | 1 byte |
Sound data section is the most complex section among all. It contains the data for arbitrary number of melodies.
Contents | Size |
Number of melodies ( = nMEL) | 1 byte |
Address table for the melodies. Address is in relative to the top of sound data section. First melody's address is always 0x0001 | 2 * nMEL bytes |
Melody data | depends on the length of each melody |
Melody data consists of :
Contents | Size |
Tempo of the melody | 1 byte |
Number of notes ( = nNOTE ) | 1 byte |
Data for each note | 4 * nNOTE bytes |
Each note consists of:
Contents | Size |
Key: 'C', 'c', 'D', 'd', 'E', 'F', 'f', 'G', 'g', 'A', 'a', 'B' ('x' for rest) | 1 byte |
Octave (supported range is from A3 to B6) | 1 byte |
Enumerator for length | 1 byte |
Denominator for length | 1 byte |
Thanks for sharing this post! I love playing math quiz games and I am really surprised knowing that every computer game is designed according to mathematics formulas. Mathematics is my favorite subject and I have learned many things from this resource- https://plainmath.net/ watching video tutorials on mathematics. During the lockdown time, I was practicing math equations with the help of their tutorials. Thanks again for sharing this interesting math quiz!
