open the concept model : m1.scad in openscad
export to stl parts you need to be printed
rotate the recipe enough to start the loop
stop it before it break
register and share the movie
or
adapt the concept to your need : for example you need to clean water while making electricity
then you must
- correct the in for water
- correct the number of rotations (the concept model is made to accelerate until it is broken)
- add an out for clean water
- add an out for unclean water
- add magnets to generate your needed electricity
as i am for stellarism i want to work on real spaceship (not rocket) to begin...
i have projects for stellarism...
bad math, some good ideas
