"Fuck" note SAO
Let the con know how you feel with this attractive and relevant SAO
Public Chat
This is a simple badge that can help you express yourself. Press the button at the bottom to illuminate your current mood. Hold it down for a second or two and let the SAO decide.
This project is prototype-complete and functions as intended. The code is good and so is the circuitry, and so not likely to change. The graphics and text on the board MIGHT change a bit. The BOM needs to be updated. The whole project is in Github. Enjoy!
A final (hopefully) revision to the pcb design
Portable Network Graphics (PNG) - 78.82 kB - 04/01/2024 at 04:07
Preview
PXL_20240401_040314475.mp4
Video of the touch function
MPEG-4 Video - 15.62 MB - 04/01/2024 at 04:07
Download
Just a pic.
JPEG Image - 2.40 MB - 04/01/2024 at 04:07
Preview
  • Final Revision?
    hexum06404/01/2024 at 04:13 0 comments
    Decided to update the SAO based on a few suggestions. Rearranged the phrases. Reworked the PCB layout. Replaced the physical button with the middle-finger dude as a touch pad. Changed the dude to a hasl pad instead of a screen print. Also tried to make the whole thing look better by moving the resistors for the LEDs next to the MCU and put an ink blot graphic over the components to hide them a bit.
    The code was basically stolen from the QTouch examples which made it an order of magnitude bigger and more complex, but the rest of the very basic functionality is the same.
View project log
