The Anthilla Controller Board is a flexible controller for IoT projects. It can be easily adapted for different needs. The board has the Rasperry-pi form factor to fast the integration.
Extended range temperature
Input power: 7V - 28V. The board can be powered by just powering 5V area.
4 Digital inputs
6 Open collector outputs
4 Analog inputs (16 bit ADC) or 4-20mA inputs switchable (multiplexed)
RS485 communication
Real time clock
Rechargeable LiPo battery
I2C and SPI communication
USB-C port
The project is stable.
The version M2-R4 is under review and being validated.
If you would like to know more about the board and receive a quotation, contact projects@anthilla.com
