1Step 1
1) The circuit board is very simple and only uses two different components, two (2) Grove connectors and a single 1 Million Ohm resistor (0603). Solder these components on the board, and you're done!
2Step 2
2) If you prefer to use your own wiring, there are a separate set of holes available for directly soldering wires to the board.
Pattern Agents
