I fly RC planes, lately I only fly a DLG but I want to film it since I fly alone, that's what this is for. The ML part is basic (find the plane) then focus on it. This project will not be zoomable since it uses an off the shelf camera eg. most likely the standard v3 raspberry pi camera module.
There will definitely be a redesign of the body to address size, staying on the hat better and recently to swap batteries. The LCD sips up power it turns out.
It is using software (ESP32) to hardware serial (RPi).
Figured out the code to program the touch screen so I made own basic one to start/stop and track elapsed time.
Soldered it so now it has the top board as initially envisioned.
It is now much bulkier.
There is still more work to do but I have all the base parts in eg. bi-directional communication.
I have some more design/printing to do so it stays on straight on my hat. Next time there is good weather fly and record footage for training the ML model which is an unknown to me at this time.
Oh man I wish I chose 5 min instead of 15 min increments... (I ran out of time with the AP controller, ran into problems, so made it auto record on boot)
It was not a complete failure and I had a great flight, also a surprise creature (a hawk moth) graced me with its presence
Warehouse work has been making me lose weight though that's good
Sample hand landing video frame
The hawk moth
Video, this is processing right now, going to sleep
It took me a couple of tries to get a good clip design, this was freehanded curves
Then the clip I had to get right, the connector was in the way so I went with a split design
I'm printing the body above, it's just over 2 hours
I'll then assemble this and start programming the AP interface, the display will not be functional yet till I figure out how to program it/use it with the RPi via maybe i2c, if nothing else as buttons
Measure thrice... print thrice?...
I really am doing a poor job on this project, I have to get it done and I have other things I'm thinking about (life problems).
But tomorrow will happen, I will be there at that field.
Basic power system wired
It'll look like this plus the bottom clip attached
I have to reprint it again because I forgot to paste back in the T shape thing that supports the back of the pi... and the pi mounts in the front are too weak/they keep snapping in the process of removing the supporting material... 2.5 hr print gotta do it again...
When I was screwing around with Brilliant Labs' Monocle I had designed this swivel thing that you could tighten. This clip camera can use the same.
My eyes are in pain, I probably dragged like 300+ pallets today and covered many miles. Sucks to suck. Phone screen tomorrow though. It's a binge day too went shopping got that good good (food).
I'm gonna crap out a body tonight since I have to write the code tomorrow for Tuesday
I can print for another 5-6 hrs. Drinking this right now got it for 50 cents at WalMart
Alright first I'll prototype the clip, a random S-shaped squighly should work. The form factor is primarily based around the Pi Zero's major dimensions. The Pi Zero W will have a 40-pin female header on it.
New battery for my caliper too nice.
I'm actually excited about the potential applications of this thing... you can connect a browser window to the livestream and included it in a video for example or seeing my hands control the sticks as I fly and recording myself taking photos with my other pi cam projects ha.
Damn I'm struggling, mind hurts
Ugh... I just feel bad... tomorrow... next update, physical build
I gotta read up on this, how to program it, I'm expecting it to have serial between the display and the pi... so I can transfer the IMU data while it's recording
I gotta figure out the graphics library and make a basic interface
Maybe you don't have to program it that way... you can use the SPI display to output a menu built with python/PIL and then get the touch coordinates to know what was clicked, that would be pretty easy to do, no flashing of the display firmware -- no it does not work that way haha... yeah Arduino or something else
I was imagining this... like a purpose... to use the IMU values for head tracking and get some kind of insight like climbing/direction idk...
Still nothing substantial done, today's a work day and I am mentally drained after these 10 hr factory shifts
In order to ensure that I succeed on Tuesday (this thing is built and it records) I am going to go with the AP approach... the display won't be functional, rather the RPi hosts a web app to control it since that's all familiar tech to me and I can bust it out
