As we all know, programming is a challenging process, which mixes of frustration and triumph as we achieve our goal. Our job is to deliver you the most aesthetic Arduino-compatible board for all your DIY adventures!
What do you imagine when you think about a DIY project with electronics inside? A standard blue board with some wires? Meh... Before starting this project, we thought the same way. Let's change the vision! Let's swap the blue board for an aesthetic black one with an Anime girl on it.
Whether you`re into DIY projects, embedded programming or just a collector we believe you’ll love AssDuino UNO as much as we do.
Good luck in programming! Its as easy as normal arduino
ATmega328P microcontroller
