• 1
    3D-print the base of the ring
    The STL file can be found in the files section. The ring size is 8, so it may not fit everyone's pointer finger.
  • 2
    Insert the battery
    Wire the "+" and "-" terminals out. It's recommended to use 30-32AWG enameled copper wire.
    In the picture above and all remaining instructional pictures, the red wire signals power or "+".
  • 3
    Install the slide switch
    Connect the red wire (the battery's "+") to one end of the switch and solder another wire to the other end.
