Turn Coordinator
05/21/2024 at 15:55 • 0 commentsAfter finishing the GNS 430 installation, I moved on to the analog instruments of the dashboard.
A great source of inspiration, as well as Fusion 360 designs, is Captain Bob's YouTube channel, which features a variety of aviation-related projects. Inspired by his content, I decided to try his design for a Turn Coordinator. I used his design almost unchanged; however, I applied the same technique for the text and graphics on the instrument that I also used in the GNS 430 build: instead of using stickers, I embossed the text and lines directly onto the 3D-printed faceplate and then painted them white with a paint pen:
Although Captain Bob's design was intended for FDM printers, I had no trouble adapting it for my resin printer. Additionally, since I don't own a laser cutter, the clear screen is not a laser-cut piece of acrylic glass as originally designed, but rather a simple overhead transparency sheet cut with my trusty eight-year-old Silhouette Portrait cutter. It looks surprisingly convincing and also serves as dust protection for the instrument.
After a first dry fit, I decided to redesign the little airplane needle, as Captain Bob’s version is tailored for a Cessna 172, whereas I am building a dashboard for a Piper Arrow III. Using close-up screenshots from my flight simulator as a reference, I designed this alternative instrument needle in Fusion:
If someone is interested, here's the Fusion file: https://bitbucket.org/zaggo/pa-28-dashboard
And here's the final design:
The instrument is powered by two X27-168 stepper motors, one driving the airplane needle (turn rate) and the other controlling the "ball" (slip rate). Unfortunately, I encountered issues when trying to drive these motors directly from AirManager, even though these motors are used in their example code for driving stepper motors. After discussing this in their forums, I received a suggestion to reduce the motor speed in the code, which kind of worked. However, the motion of the needles was still quite jerky and slow, which I found unsatisfactory. During this process, I also experimented with controlling the motors using an Arduino sketch and the SwitecX25 library. This approach worked immediately and was significantly smoother than the jerky AirManager driver.
Fortunately, AirManager also offers a library for Arduino, SiMessagePort, which facilitates communication between AirManager and any Arduino sketches. Therefore, I decided to integrate an additional dedicated "Stepper Driver" Arduino into my build.
Here's the current simple sketch for driving the X27 motors based on commands sent via the SiMessagePort by AirManager:
#include <SwitecX25.h> #include <si_message_port.hpp> // standard X25.168 range 315 degrees at 1/3 degree steps #define STEPS (315*3) SiMessagePort* messagePort; // For motors connected to digital pins 4,5,6,7 SwitecX25 motor1(STEPS,4,5,6,7); SwitecX25 motor2(STEPS,8,9,10,11); static void new_message_callback(uint16_t message_id, struct SiMessagePortPayload* payload) { if (payload == NULL) { return; } if (payload->type != SI_MESSAGE_PORT_DATA_TYPE_FLOAT) { return; } float relPos = payload->data_float[0]; messagePort->DebugMessage(SI_MESSAGE_PORT_LOG_LEVEL_INFO, (String)"Received position: "+relPos+" for motor: "+message_id); switch(message_id) { case 1: motor1.setPosition(relPos * STEPS); break; case 2: motor2.setPosition(relPos * STEPS); break; } } void setup(void) { // Init library on channel A and Arduino type MEGA 2560 messagePort = new SiMessagePort(SI_MESSAGE_PORT_DEVICE_ARDUINO_MEGA_2560, SI_MESSAGE_PORT_CHANNEL_P, new_message_callback); // run the motor against the stops motor1.zero(); motor2.zero(); // start moving towards the center of the range motor1.setPosition(0); motor2.setPosition(0); messagePort->DebugMessage(SI_MESSAGE_PORT_LOG_LEVEL_INFO, (String)"Servos zeroed and driver ready"); } void loop(void) { messagePort->Tick(); // the motor only moves when you call update motor1.update(); motor2.update(); }
And here's the companion LUA script in AirManager:
function new_message(id, payload) -- Do something with the message from the Arduino end servo_driver = hw_message_port_add("ARDUINO_MEGA2560_P", new_message) function turnrate_callback(deg) -- value between 0.0 ... 1.0, 0.5 = 0° 0.2=-90° 0.78=+90° local clippedDeg = var_cap(var_round(deg,3), -110, 110) local v = 0.5 + (clippedDeg/90) * 0.29 -- print("Turnrate: "..deg.." clipped: "..clippedDeg.." v = "..v) hw_message_port_send(servo_driver, 1, "FLOAT", v) end xpl_dataref_subscribe("sim/cockpit2/gauges/indicators/turn_rate_roll_deg_pilot", "FLOAT", turnrate_callback) function sideslip_callback(deg) -- value between 0.0 ... 0.156 0° = 0.082 local zeroPos = 0.087 local clippedDeg = var_cap(var_round(deg,3), -90, 90) local v = zeroPos + (clippedDeg/90) * (0.156-zeroPos) local clippedV = var_cap(v, 0, 0.156) -- print("Sliprate: "..deg.." clipped: "..clippedDeg.." v = "..v.." clippedV = "..clippedV) hw_message_port_send(servo_driver, 2, "FLOAT", clippedV) end xpl_dataref_subscribe("sim/cockpit2/gauges/indicators/sideslip_degrees", "FLOAT", sideslip_callback)
With this setup, the Turn Coordinator works well, and the extra Arduino is not only driving these two X27 motors but also potentially other steppers and other unique devices in the future.
It would be ideal if AirManager could natively support these commonly used steppers more effectively. However, I must acknowledge that they offer a valuable workaround with their SiMessagePort library for Arduino, which opens up a lot of potential for future expansions.
The GNS 430 GPS
05/01/2024 at 11:46 • 1 commentThe first device I built was the GNS 430 GPS unit. Here's the finished thing:
I wanted this to have with backlit buttons and real dual rotary encoders. After searching the web for a while it became clear, that I had to design this myself.
The screen content comes directly from the flight sim. But since I'm currently running the sim on a Macbook Pro, and thus do not have an option to connect too many external displays, I use AirManager for grabbing the GPS' display content directly from XPlane and sending it via a network connection to a Raspberry Pi 4. This works surprisingly well, even over wifi. Unfortunately the Raspberry doesn't have enough GPIO pins to also drive all the buttons and encoders. I originally planned to build two GNS 430 units anyway (as there are two of them in the simulator) and it's no problem for the Raspberry Pi 4 with its 2 HDMI connectors (and the AirManager/AirPlayer combo) to provide the display content for both of them. So I decided to use a separate Arduino Mega 2560 for interfacing with all the hardware buttons and encoders. To my pleasant surprise, it's even possible to connect the Arduino(s) directly to the Rasperry Pi and setup AirManager/AirPlayer in such a way, that all information is transported via the netrwork connection. This greatly reduces the need for cables between the dashboard and the computer. In fact, there is actually 0 (zero) cables between the main computer and the dashboard, since everything is working great so far with just a WiFi connection between the Mac and the Raspberry Pi. The only cable going to the dashboard is a power cable!
Here's the current wiring schematic of the GNS 430:
I did draw the whole design in Fusion. I was able to use some parts (like the rotary encoders) from GrabCAD, but most parts (including the backlit push buttons and the LCD) I drew myself.
After a few failed test prints of the tiny push button covers with my > 10 years old LulzBot TAZ 6 it was clear, that a FDM printer wouldn't cut it (at least mine). So after more than 15 years of FDM printing, I decided that it would be time to give resin printers a try and bought a Elegoo Mars 3 Pro.
Using a resin printer after years and years of FDM printing is maybe a story for a different time, but I finally managed do successfully print first push buttons!
I printed these with clear resin and airbrushed them black afterwards. Finally I sanded off the black coating from the embossed text and voila: A backlit push button:
I ordered most of the hardware for cheap from Ali Express (rotary encoders and a bag of 100 pcs "6x6x7mm through hole reset micro push button tactile momentary switch with led (white)"), and a 4 inch IPS display with HDMI port from Amazon (not so cheap).
The white text on the frontpanel and the encoder knobs is also 3D printed, embossed text. But this time the part was printed with black resin and the embossed text later painted white (with a white paint pen).
And here's the thing, all cabled up, after assembly:
On the software side, I wrote a LUA script for my GNS 430 in AirManager (I'm new to AirManager and also LUA, so please let me know if I can optimize the code!).
The LCD-Content is fetched from XPlane and send to the AirPlayer instance on the Raspberry Pi with this simple command:
video_stream_id = video_stream_add("xpl/GNS430_1", 0, 0, 800, 480)
All the buttons and encoders are then mapped by a script, running on the Arduino Mega:
------------------ -- GPS PushButtons ------------------ cvol_event = 0 function cvol_pressed() print("cvol_pressed") xpl_command("sim/GPS/g430n1_cvol", "BEGIN") local event = cvol_event timer_start(2000, function(count) if event == cvol_event then print("Shutdown") shut_down("SYSTEM") end end) end function cvol_released() cvol_event = cvol_event + 1 -- print("cvol_released, cvol_down is now "..cvol_down) xpl_command("sim/GPS/g430n1_cvol", "END") end hw_button_add("CVol", cvol_pressed, cvol_released) function vvol_pressed() print("vvol_pressed") xpl_command("sim/GPS/g430n1_vvol", "BEGIN") end function vvol_released() xpl_command("sim/GPS/g430n1_vvol", "END") end hw_button_add("VVol", vvol_pressed, vvol_released) function comff_pressed() print("comff_pressed") xpl_command("sim/GPS/g430n1_com_ff", "BEGIN") end function comff_released() xpl_command("sim/GPS/g430n1_com_ff", "END") end hw_button_add("Com FF", comff_pressed, comff_released) function navff_pressed() print("navff_pressed") xpl_command("sim/GPS/g430n1_nav_ff", "BEGIN") end function navff_released() xpl_command("sim/GPS/g430n1_nav_ff", "END") end hw_button_add("Nav FF", navff_pressed, navff_released) function nav_com_tog_pressed() print("nav_com_tog_pressed") xpl_command("sim/GPS/g430n1_nav_com_tog", "BEGIN") end function nav_com_tog_released() xpl_command("sim/GPS/g430n1_nav_com_tog", "END") end hw_button_add("NavCom Toggle", nav_com_tog_pressed, nav_com_tog_released) function cdi_pressed() print("cdi_pressed") xpl_command("sim/GPS/g430n1_cdi", "BEGIN") end function cdi_released() xpl_command("sim/GPS/g430n1_cdi", "END") end hw_button_add("CDI", cdi_pressed, cdi_released) function obs_pressed() print("obs_pressed") xpl_command("sim/GPS/g430n1_obs", "BEGIN") end function obs_released() xpl_command("sim/GPS/g430n1_obs", "END") end hw_button_add("OBS", obs_pressed, obs_released) function msg_pressed() print("msg_pressed") xpl_command("sim/GPS/g430n1_msg", "BEGIN") end function msg_released() xpl_command("sim/GPS/g430n1_msg", "END") end hw_button_add("MSG", msg_pressed, msg_released) function fpl_pressed() print("fpl_pressed") xpl_command("sim/GPS/g430n1_fpl", "BEGIN") end function fpl_released() xpl_command("sim/GPS/g430n1_fpl", "END") end hw_button_add("FPL", fpl_pressed, fpl_released) function proc_pressed() print("proc_pressed") xpl_command("sim/GPS/g430n1_proc", "BEGIN") end function proc_released() xpl_command("sim/GPS/g430n1_proc", "END") end hw_button_add("PROC", proc_pressed, proc_released) function rng_dn_pressed() print("rng_dn_pressed") xpl_command("sim/GPS/g430n1_zoom_out", "BEGIN") end function rng_dn_released() xpl_command("sim/GPS/g430n1_zoom_out", "END") end hw_button_add("RNG Down", rng_dn_pressed, rng_dn_released) function rng_up_pressed() print("rng_up_pressed") xpl_command("sim/GPS/g430n1_zoom_in", "BEGIN") end function rng_up_released() xpl_command("sim/GPS/g430n1_zoom_in", "END") end hw_button_add("RNG Up", rng_up_pressed, rng_up_released) function direct_pressed() print("direct_pressed") xpl_command("sim/GPS/g430n1_direct", "BEGIN") end function direct_released() xpl_command("sim/GPS/g430n1_direct", "END") end hw_button_add("DIRECT", direct_pressed, direct_released) function menu_pressed() print("menu_pressed") xpl_command("sim/GPS/g430n1_menu", "BEGIN") end function menu_released() xpl_command("sim/GPS/g430n1_menu", "END") end hw_button_add("MENU", menu_pressed, menu_released) function clr_pressed() print("clr_pressed") xpl_command("sim/GPS/g430n1_clr", "BEGIN") end function clr_released() xpl_command("sim/GPS/g430n1_clr", "END") end hw_button_add("CLR",clr_pressed, clr_released) function ent_pressed() print("ent_pressed") xpl_command("sim/GPS/g430n1_ent", "BEGIN") end function ent_released() xpl_command("sim/GPS/g430n1_ent", "END") end hw_button_add("ENT", ent_pressed, ent_released) function cursor_pressed() print("cursor_pressed") xpl_command("sim/GPS/g430n1_cursor", "BEGIN") end function cursor_released() xpl_command("sim/GPS/g430n1_cursor", "END") end hw_button_add("CRSR", cursor_pressed, cursor_released) -- Create a new rotary encoder function page_change(direction) if direction == 1 then print("The page turned clockwise") xpl_command("sim/GPS/g430n1_page_up", "ONCE") end if direction == -1 then print("The page turned counterclockwise") xpl_command("sim/GPS/g430n1_page_dn", "ONCE") end end hw_dial_add("PAGE", page_change) -- Create a new rotary encoder function chapter_change(direction) if direction == 1 then print("The chapter turned clockwise") xpl_command("sim/GPS/g430n1_chapter_up", "ONCE") end if direction == -1 then print("The chapter turned counterclockwise") xpl_command("sim/GPS/g430n1_chapter_dn", "ONCE") end end hw_dial_add("CHAPTER", chapter_change) -- Create a new rotary encoder function cv_fine_change(direction) if direction == 1 then print("The cv_fine turned clockwise") xpl_command("sim/GPS/g430n1_fine_up", "ONCE") end if direction == -1 then print("The cv_fine turned counterclockwise") xpl_command("sim/GPS/g430n1_fine_down", "ONCE") end end hw_dial_add("CV_FINE", cv_fine_change) -- Create a new rotary encoder function cv_coarse_change(direction) if direction == 1 then print("The cv_coarse turned clockwise") xpl_command("sim/GPS/g430n1_coarse_up", "ONCE") end if direction == -1 then print("The cv_coarse turned counterclockwise") xpl_command("sim/GPS/g430n1_coarse_down", "ONCE") end end hw_dial_add("CV_COARSE", cv_coarse_change) -- Create a new rotary encoder function cvol_change(direction) if direction == 1 then print("The cvol turned clockwise") xpl_command("sim/GPS/g430n1_cvol_up", "ONCE") end if direction == -1 then print("The cvol turned counterclockwise") xpl_command("sim/GPS/g430n1_cvol_dn", "ONCE") end end hw_dial_add("C_VOL", cvol_change) -- Create a new rotary encoder function vvol_change(direction) if direction == 1 then print("The vvol turned clockwise") xpl_command("sim/GPS/g430n1_vvol_up", "ONCE") end if direction == -1 then print("The vvol turned counterclockwise") xpl_command("sim/GPS/g430n1_vvol_dn", "ONCE") end end hw_dial_add("V_VOL", vvol_change)
Maybe the most fancy feature on this code is right at the beginning, where I managed to translate a "long press" on the "Pwr VOL/SQ" encoder button to a system shutdown of the Raspberry Pi. That way, I'm able to correctly shut down the Raspberry without the need for a SSH shell or just cutting the power and hoping for the best.
What am I doing?
05/01/2024 at 09:54 • 0 commentsWell, here's a screenshot of a Piper Arrow III Dashboard in X-Plane:
And I try to build most of it.
As said before: I already own a Yoke and Rudder pedals, which are fine and I currently do not intent to build these from scratch.
This might be different if I'd plan to build a full cockpit, but unfortunately there's no space for this in my apartment. So a desktop cockpit it'll be and the existing yoke with its table top screw clamps works great for this use case.
So, based on the above screenshot and the existing hardware, I came up with this layout:
So most instruments will be in their original place. Some components needed to move, since my dashboard will end on the tabletop. So, for example, I moved the starter key slightly from it's position slightly "under the tabletop" to a free space above. Same thing for the fuel tank selector, which is originally located down by the knee of the pilot, on the left wall of the cockpit, to a free space next to the starter key (I also sized it down).
I don't have to build the throttle, prop and mixture levers, since these are part of the existing yoke assembly. But I had to move the alternator amp and fuel pressure gauges out of the way for the yoke cutout.
There's no space for the fuel and oil pressure/temp gauges, which are originally also below the "tabletop line". I'll figure something out later...
All the switches for the lights and avionics will be more or less in their original spots.
And I'll fill the stack of electronics above the switches (like GPS, Transponder, Autopilot etc.) dynamically as I build them. They should have all more or less the same width, which means, that I can rearrange them as needed in a large rectangular cutout (like in the real dashboard).
The backplate will be out of 5mm plywood, somehow fixed to the yoke and/or tabletop, so everything will be easily setup in a few minutes. However, the exact structural framework is yet unclear for now.
