Instructions:
## Prints
For the whole setup you need to print the following parts. Some might need support with your printer or could be seperated and put together later with glue.
### For the Case
- case_with_socket
- gutter_kirby
- kirby (I mid-print changed the filament twice to gett all his colors. First white, then pink and finally black)
- nut_grippy
### For the star light
- star_body
- star_lid
- tube_segment_bottom_end
- tube_segment_top_end
- tube_segment_tall / _small (as many as you need)
### For the arm
- barrel-holder (if you use one of [these](https://www.amazon.de/MANDDLAB-St%C3%BCck-Power-Socket-Barrel-Type/dp/B0CPSDVC7F/ref=sr_1_4?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=2WBXCLZCNMPF&dib=eyJ2IjoiMSJ9.guZuSlaP26fvNbe4wWFNZlAJTJdVzCRr6UH_72LYkHdxLNXkJETF3Pv_oqJb9QMQGqYQP-LezKbY5taMy_z2pkXckWNmB3wzDbtw5cQn1kWLHnqR1xFArxiqE2miYEFn39ff_99N6Tocv7fepbNM9vH6Id_dVkw5rVzQ8eHmMm03mto6uUO6sI_bUzCJW9X6EeJrl9fT5oZMO5Hwk_W8HWG0JUCq1us75PPIZ9W3w3c.12IWkYNWAlLvvaL2XQsQgK-vrytKtu96mUdK-LDDD4c&dib_tag=se&keywords=barrel+jack+socket&qid=1714686247&sprefix=barrel+jack+socket%2Caps%2C129&sr=8-4) for the the power connector)
If you want to go without the arm, just leave these parts out. If you want to replace kirby with a honey-comb gutter print "gutter" instead of "gutter_kirby" and "kirby"
## What else is needed
A 12v 120mm x 120mm x 25mm DC or PWM Fan. [That's the one I used](https://www.amazon.de/gp/product/B07GB6D7VQ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1)
The flexible arm i used is [here](https://www.amazon.de/gp/product/B0B4FWXZZ1/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1)
A 12v power supply, if light is used at least with 0.42A. Like this one [these](https://www.amazon.de/Netzteil-AGOTD-Transformator-220-240V-Streifen-schwarz/dp/B0CGD23B6G/ref=sr_1_6?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=2YHIWOQ8FDNSG&dib=eyJ2IjoiMSJ9.ZwohkQVYROXaQGaP3MM9hs6uFTcIGLyyIJj29SrTL0l8w2N4960sQ8v1DqED2E6HK_gemIYbGDjw0U6qM47kYhCpua-VwasrwI7AAcp_5vvFwc58SVb2FG8L-deYxNhFBZaiMaWGs5yawBxJ028padGPMElLYdGUmuaPKwHTxiWP7L6bo5NGW3Al46xC8M3ygrsR0QTMrZaF7kj53rsVnPYiA_Qwdt48CLjlar-03krm08suPajt0-oIbUsWXkWL9-dyHAWrKy_DyE15hP2BBpmCemyjLqLJGlVaRCwxq7M.EJ3ddWtVreEMYJQ2HtBGqHIx905W7jwDH_ezKbub0vQ&dib_tag=se&keywords=12v%2Bpower%2Bsupply&qid=1714684594&s=ce-de&sprefix=12v%2Bpower%2Bsupply%2Celectronics%2C132&sr=1-6&th=1)
That kind of [LED](https://www.amazon.de/Auting-Warmwei%C3%9F-Halogenlampen-Energiesparlampe-Dimmbar/dp/B0BZ8986C3/ref=dealz_related_t1_d_sccl_2_4/260-4366050-2125305?pd_rd_w=RS0K5&content-id=amzn1.sym.1f4afbac-81ba-481c-b3ef-024210f3433c&pf_rd_p=1f4afbac-81ba-481c-b3ef-024210f3433c&pf_rd_r=V06CSP7RFDRMMPTQPRR7&pd_rd_wg=TiZv5&pd_rd_r=f2c80e32-9223-4929-a6e4-4915243f536b&pd_rd_i=B0BZ8986C3&th=1)
Two of these [charcoal mats](https://www.amazon.de/Aktivkohlefilter-St%C3%BCck-13cm-L%C3%B6ten-Rauchabsorbern/dp/B07WR72S4Y/ref=sr_1_3?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=3EFLHBUR8DWCE&dib=eyJ2IjoiMSJ9.HigXdEQeoB6wkcE2wnbu1dh-NqVR6x6y179QlL-yyY0yuaM1nsw_hYHF_9MgLBc9LpE1dIjbtqF2iE7xWRfeJIrmgxOVp75xfrZlXSMm0x0h2vv2Zqgajv1qnBJ9tGAOn5xiY2DtxXTjIC8_K2Ju-Fqil8ddu8KRImy_RJtnNlGnzmRfusxcuUE98BsCG49qAGYB9r9KcsAiM05JoFAa5xKDrLCA8Cb7KDobfrKsLzJic9iUSL4Yr1YVHe0nFBlE6LSEjmIASQ07IHDXK75ZoK920hbTxNeBjc3HnhYcKaA.WdyB7ydsRBqoRKroVIsXOJN5A5tOhIApulW9i0a6MEE&dib_tag=se&keywords=120+aktivkohle+matte&qid=1714685099&s=kitchen&sprefix=120+aktivkohle+matt%2Ckitchen%2C161&sr=1-3)
and a simple on/off switch that fit's into a 6mm x 10mm hole. like [this one](https://www.amazon.de/GUMEI-Position-Vertikaler-Schiebeschalter-SS12D00G3/dp/B09BZ8LF55/ref=sr_1_57?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&crid=2KCQCJR1JU28I&dib=eyJ2IjoiMSJ9.skTJpcTDSid2U0OT67lLeLBdeGyGBBJgDwAHuLg7Iut1YNx53MQ3gl0g-BDj7kv_fnvf4Yu8UiFKR6-jOcbwgrcYlnyahaznLxRzqe7TsRDh8Rechz0JQtUL9TctKndCFh9H8zjT4VihiVZNCgvanq0BZsfTkouHHcK1BMhSoTbV6Qrw523qBPx62K54tBxX.6OwzHa8xuUdmjYGuqizpgBFj51LC5CYaGe_hbI3N3eo&dib_tag=se&keywords=on+off+switch+10mm+6mm&qid=1714685383&sprefix=on+off+switch+10mm+6mm%2Caps%2C131&sr=8-57&xpid=eCB83v2zy7zDA)...
