Pomelo: Hand-held gamma-ray spectrometer
Battery-powered instrument for gamma spectroscopy with ample interfacing options
Pomelo is a stand-alone instrument for gamma-ray spectroscopy. It uses a CsI(Tl) scintillator to measure gamma ray energies and can be operated using its buttons & graphical LCD interface. The hardware also supports USB, WiFi, Bluetooth, ZigBee, and an SD card. The whole thing is powered by a rechargable 18650 battery. Pomelo will be launching on Crowd Supply https://www.crowdsupply.com/pomelo-instrumentation/pomelo
Pomelo is a complete instrument for hobby-level gamma spectroscopy. It is built around the Pomelo Core and Physics which handle all the radiation detection, but adds a user interface and ample communication in the form of an Arduino-compatible ESP32-C6 add-on board, the Pomelo Zest.
Pomelo Zest board displaying a Th-232 spectrum in logarithmic scale
The Pomelo Zest features:
A brief user interface demo of the instrument is shown in the following video.
The Pomelo Zest can be used as a generic ESP32-C6 development board, but its mechanical design is built to match the Pomelo Core and Physics so it might not be optimal because of the battery and power button placement.
Block diagram
Detector block diagram showing available connectivity for the system components. The Pomelo Core can still be accessed from a computer through USB for control and firmware update even while it also connected to the Zest
The software on the Pomelo Zest is written in the Arduino environment so it is very easy to follow and modify, but not optimized for low power consumption. However, the Pomelo Core stays powered when the Zest is switched off, so data can still be accumulated using little power.
Schematic
Pomelo Zest schematic
  • Pomelo on Crowd Supply
    mihai.cuciuc02/21/2025 at 15:05 0 comments
    Pomelo will be launching on Crowd Supply where you can subscribe to be notified when it's ready: https://www.crowdsupply.com/pomelo-instrumentation/pomelo
    I'm more of an engineer than a business person, so the business side of things is full of novelty for me. But it's an interesting challenge.
  • WiFi connectivity
    mihai.cuciuc08/19/2024 at 05:09 0 comments
    Pomelo Zest offers WiFi connectivity thanks to the ESP32-C6 at its core. It can either connect to an existing network or run in access point mode to allow a phone or a laptop to connect to it for accessing the web user interface.
    An overview of this functionality is in the following clip, with some more detail below.
    To make connection as easy as possible it can display the WiFi credentials (when in AP mode) and web UI link as QR codes ready to be scanned by a phone
    Web interface as presented on a laptop and a phone
    The web user interface is pretty basic, having run information and controls as well as a spectrum view implemented using the very tiny and awesome uPlot library. This allows having all assets locally, as you might not be online when connected to Pomelo.
    We gamma spectroscopy nerds really care about poking at the gamma spectra looking for peaks and making sure the energy resolution of our instrument is as advertised. A lot of excellent software has been written for this and one of my favourites is InterSpec. Pomelo offers a minimal N42 file as a download with the current spectrum and its calibration coefficients, such that it can immediately be loaded into InterSpec.
    InterSpec showing gamma spectrum loaded up from Pomelo
  • Radiation mapping
    mihai.cuciuc07/29/2024 at 17:59 0 comments
    Check out the interactive version of the map here: http://pomelomap.s3-website.eu-central-1.amazonaws.com
    I strapped a GPS module to one of the Pomelo Zest prototypes and drove it around for the past week. It logs positioning and spectrum data to text files on an SD card and I then read all those text files in a python script to generate a map using Folium. Individual measurement points are grouped together in squares on the map and all the spectra from these measurements are added together to calculate an average dose rate at that point. You can click a square to see the associated spectrum.
    GPS module jerry-rigged onto detector
  • Updated scintillator and power consumption
    mihai.cuciuc06/19/2024 at 17:30 0 comments
    Pomelo detector on the shoulders of giants
    I got the scintillators I intended to use with this detector and have some performance plots with them in this project log. With them the hand-held detector is also starting to look better. I added top & bottom laser cut acrylic plates as basic protection of both electronics as well as of fingers from the ~80V generated by the bias circuit.
    The detector consists of a top user interface & connectivity board based on the ESP32-C6 (Pomelo Zest), and a bottom gamma spectroscopy board (Pomelo Core). The power consumption of these two boards can be measured individually:
    Pomelo Core:
    • active: ~3 mA at background radiation levels
    Pomelo Zest:
    • active, connected to WiFi: 50 mA
    • active, LCD backlight on: 70 mA
    • active: 40 mA
    • light sleep: 0.7 mA
    • deep sleep: 0.35 mA
    • deep sleep with SD card inserted: 0.65 mA
    On future board revisions I intend to gate the power to the LCD and SD card.
    Here are some pictures of the detector with its laser cut acrylic protection plates.
View all 4 project logs
Gianmarko72 wrote 06/13/2024 at 08:02 point
this is a very interesting project.
is it going to be available in some form like kit?
mihai.cuciuc wrote 06/19/2024 at 16:17 point
Hi! Yes, that is the plan :) But it might take a while until I'm actually ready to sell these. Hardware is pretty advanced, but getting all the paperwork in order is something I'm not very experienced with.
Gianmarko72 wrote 06/25/2024 at 06:29 point
Hi Mihai
we will patiently wait :-)
kogosi wrote 06/07/2024 at 07:02 point
Hi, i´m Ralf. What Type ist the scintillator? I dont find anything in the Net. Thanks. Ralf from Germay ;-)
mihai.cuciuc wrote 06/19/2024 at 16:15 point
Hi, Ralf! I used a CsI(Tl) scintillator from OST-Photonics: https://www.ost-photonics.com/product/10-mm-x-10-mm-x-30-mm-csitl-scintillation-crystal/
It's 3 cm^3, but I've since switched to 2 cm^2 ones :)
Gianmarko72 wrote 06/25/2024 at 06:30 point
Hi Mihai
why move to smaller scintillators? i thought the bigger the better (more chances to catch an event)
mihai.cuciuc wrote 06/25/2024 at 06:45 point
Hi, Gianmarko! The main reason I moved to smaller scintillators was that I read in someone's thesis that the reflective wrapping I use for the crystal works best when the aspect ratio of the crystal was at most 2:1. The previous crystals were 30 mm long with a base of 10 mm x 10 mm. Another reason is cost, as the price of the crystal goes quite linearly with size. Now the crystal and SiPM are in the same ballpark :)
