Everyone knows good startups start with good design. These days even vulnerabilities become known (and addressed) only if they have good graphic design. Have you heard of CVE-2004-1315? Nope, but I'm certain you know of Heartbleed. Graphic design. What does all graphic design have in common? That's right, color. Enter the Any Colored Button.
Errrr. Yeah Contest. I've submitted to 2017 Hackaday Prize. What matters more that good design? Nothing. What do ALL designs have in common? That's right, color. The Any Colored Button can rapidly iterate your startup into it's new designy future.
Step 1. Press the button.
Step 2. .....startupy handwaving....
Step 3. Profit!
Gimme Likes. Likes = Votes. Votes = $1. $1 = Profit. Voting is Step 2 folks. Vote for The Any Colored Button.
Not sure what the benefit would be. It's only a single LED so update time isnt' an issue and at present I'm only running 3 wires total (DIN, VCC, GND). But, I'll check those out regardless for potential future use. Thanks for the tip!
you should check out the APA102C LED it uses two wires for serial but can be updated much faster than the neopixel can.
