1Step 1
Bitu CDirectLPT::Read_PR() { Bitu retval; //ioctl(porthandle, PPRDATA, &retval); return retval; } Bitu CDirectLPT::Read_COM() { Bitu retval; //ioctl(porthandle, PPRCONTROL, &retval); return retval; } Bitu CDirectLPT::Read_SR() { //Bitu retval; //ioctl(porthandle, PPRSTATUS, &retval); char b = wiringPiI2CReadReg8 (porthandle, 0x13); char retval=(b&2)<<5|(b&4)<<5|(b&8)<<2 |(b&16)|(b&64)>>3; LOG_MSG("printer raw status: %x",retval); LOG_MSG("printer oldraw statustesrt: %x",b); return retval; } void CDirectLPT::Write_PR(Bitu val){ //ioctl(porthandle, PPWDATA, &val); wiringPiI2CWriteReg8 (porthandle, 0x12, val); LOG_MSG("parallel%d: ",val); //Set all Datapins GPIOA } void CDirectLPT::Write_CON(Bitu val) { //ioctl(porthandle, PPWCONTROL, &val); Bitu controlout = (val&1)|(val&2)<<4|(val&4)<<5; //sort Controlbyte to GPIOB Outputs, Automatic Write only outputs eg Register OLATB wiringPiI2CWriteReg8 (porthandle, 0x13,controlout); } void CDirectLPT::Write_IOSEL(Bitu val) { // switches direction old-style TODO if((val==0xAA)||(val==0x55)) LOG_MSG("TODO implement IBM-style direction switch"); } void CDirectLPT::Timer2(void) { }
2Step 2
Parse Control and Status MCP Pins to Dosbox Parallel IO Registers:
// Example program #include <iostream> #include <string> #include <bitset> int main() { char a = 0b00000111; //Parallel Control Byte to Parport char ro = (a&1)|(a&2)<<4|(a&4)<<5; //MCP-Byte Control Out: 10100001 std::bitset<8> x(ro); std::cout << x; std::cout << "\r\n"; char b = 0b01011110; //Status In, Read status from MCP and parse bits as status Byte to Dosbox char ri = (b&2)<<5|(b&4)<<5|(b&8)<<2 |(b&16)|(b&64)>>3; //StatusByte MCP Read Return as Status: 11111000 std::bitset<8> z(ri); std::cout << z; }
