I have done some more research and found that most normal tablets can do palm rejection with a standard conductive rubber stylus. I will try this out with a neodymium magnet embedded to check for interference then work on the electro-magnet array.
An LCD display overlayed on a graphics tablet with an array of electro-magnets underneath. The magnetic array guides the stylus.
After some testing I have found the force to be far too low to act in the way I was intending for this project. I think the next best way of achieving my goal is to move either a permanent magnet or big electro-magnet around under the writing surface. More testing to follow.
I have decided to try winding lots of individual coils for the electromagnet array. I think that the magnetic force will need to be quite strong to have a good guiding effect. I have some fine enameled wire and one of those 'pin-art' things. I'm going to try winding a fixed length of wire on to each pin and then connect them up like an LED matrix. I think the coils will each need a series diode to work in this manner but would actually like to be able to pull and push the stylus magnet so bi-directional current would be good. Winding all of those pins and keeping track of the wire ends is probably going to send me mad! I actually want the final version to be a much bigger but am testing the theory with this small one.
