close-circle
FASTUSBasp programmer for AVR
This is the fastest usbasp for AVRs based on cheap stm32f103c8t6 board.
close
This is the fastest usbasp programmer for AVR MCUs based on cheap stm32f103c8t6 ('blue-pill') board.The price of this board is just 1.81$ in case you buy it from Aliexpress. https://www.aliexpress.com/item/Arm-cortex-m3-stm32f103c8t6-stm32-core-board-development-board/1539984258.html This is an alternate to famous USBasp AVR programmer since its cheap and fast. It has real USB hardware hence it should work without any issues.
USBasp programmer is a great programmer and uses firmware-only USB driver. I wanted to create another AVR programmer which is similar to USBasp but with real USB hardware to avoid connection issues which I had with USBasp before. The price of this board is just 1.81$ in case you buy it from Aliexpress hence it was a good alternative to USBasp.
schematic
Read more about this on my blog:
http://amitesh-singh.github.io/stm32/2017/05/21/FASTUSBasp-programmer-avr.html
Bit clock speed
FASTUSBasp starts out with a fast ISP clock frequency (default: 3 MHz), so the -B bitclock option might be required to achieve stable communication.
Supported bitclock speed
default (without -B): 3 MHz
1.5 MHz
750 KHz
375 KHz
187.5 KHz
panelizedv02.zip
it is a panelized PCBs which contanis 3 boards in 100x100 cm size.
Zip Archive - 53.13 kB - 05/21/2017 at 07:24
download-circle
Download
  • 1 × stm32f103c8t6 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × FASTUSBasp adapter board check gerber files.
View all 10 project logs
  • 1
    Step 1
    Compile
    Refer my old post on how to setup stm32 devlopment environment on Arch linux. setting up stm32 development environment
    Make sure you have compiled libopencm3 library.
    $ git clone https://github.com/amitesh-singh/FASTUSBasp
    $ vi config.cmake  # set the libopencm3 path here
    $ cmake .
    $ make
    Upload the firmware
    connect st-link programmer to blue-pill and upload the firmware
    $ make fastusbasp-upload
    How to program AVR MCUs
    Probe AVR
    $ sudo avrdude -c usbasp-clone -p m16
    avrdude: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.00s
    avrdude: Device signature = 0x1e9403 (probably m16)
    avrdude: safemode: Fuses OK (E:FF, H:D8, L:CF)
    avrdude done.  Thank you.
    Upload program to AVR
    $ sudo avrdude -c usbasp-clone -p m16 -U flash:w:blink.hex
    avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
             To disable this feature, specify the -D option.
    avrdude: erasing chip
    avrdude: reading input file "blink.hex"
    avrdude: input file blink.hex auto detected as Intel Hex
    avrdude: writing flash (150 bytes):
    Writing | ################################################## | 100% 0.02s
    avrdude: 150 bytes of flash written
    avrdude: verifying flash memory against blink.hex:
    avrdude: load data flash data from input file blink.hex:
    avrdude: input file blink.hex contains 150 bytes
    avrdude: reading on-chip flash data:
    Reading | ################################################## | 100% 0.01s
    avrdude: verifying ...
    avrdude: 150 bytes of flash verified
    Read flash
    $ sudo avrdude -c usbasp-clone -p m16 -U flash:r:flash.bin:r
    avrdude: reading flash memory:
    Reading | ################################################## | 100% 0.33s
    avrdude: writing output file "flash.bin"
    $ hexdump flash.bin
    0000000 c029 0000 c02f 0000 c02d 0000 c02b 0000
    0000010 c029 0000 c027 0000 c025 0000 c023 0000
    0000020 c021 0000 c01f 0000 c01d 0000 c01b 0000
    0000030 c019 0000 c017 0000 c015 0000 c013 0000
    0000040 c011 0000 c00f 0000 c00d 0000 c00b 0000
    0000050 c009 0000 2411 be1f e5cf e0d4 bfde bfcd
    0000060 d002 c017 cfcd 9ab8 9ac0 ef2f ed83 e390
    0000070 5021 4080 4090 f7e1 c000 0000 98c0 ef2f
    0000080 ed83 e390 5021 4080 4090 f7e1 c000 0000
    0000090 cfeb 94f8 cfff
    Flash Read/Write speed
    Flash Write speed: 15 KBps
    Flash Read Speed: 52.5 KBps
    USB debug information
    $ sudo lsusb -vv -d 16c0:
    Bus 003 Device 005: ID 16c0:05dc Van Ooijen Technische Informatica shared ID for use with libusb
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass          255 Vendor Specific Class
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x16c0 Van Ooijen Technische Informatica
      idProduct          0x05dc shared ID for use with libusb
      bcdDevice            2.00
      iManufacturer           1 ami
      iProduct                2 FASTUSBasp
      iSerial                 0
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength           18
        bNumInterfaces          1
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              100mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           0
          bInterfaceClass         0
          bInterfaceSubClass      0
          bInterfaceProtocol      0
          iInterface              0
    can't get device qualifier: Resource temporarily unavailable
    can't get debug descriptor: Resource temporarily unavailable
    Device Status:     0x0000
      (Bus Powered)
View all instructions
