FreeCAD modular private smartphone v0.02
05/05/2017 at 22:31 • 0 commentsVersion 0.02 of modular private smartphone.
It has the following parts:
· Manga screen.
· Raspberry pi zero W.
· Fona 3G.
· Powerboost 1000C. It will be changed in the future because it doesn't give enough current to power up the raspberry pi and the other components. An alternative is ups Pico , but it is very big, more alternatives will be searched:
https://www.modmypi.com/raspberry-pi/breakout-boards/pi-modules/ups-pico
· 3D printed case.
You can download the freeCAD files through the following link:
https://cdn.hackaday.io/files/21260909587840/Modular_private_smartphone_0.02.FCStd
In the next version the microphone, speaker, 3G Antena, volume control and on/off/lock/unlock button need to be included.
Updated FreeCAD assembly of the modular private smartphone
05/05/2017 at 20:09 • 0 commentsYou can download the FreeCAD file at the following link:
https://cdn.hackaday.io/files/21260909587840/Modular_private_smartphone_0.01.FCStd
The FreeCAD file has the following components:
- Raspberry pi zero W.
- Manga screen.
- Fona 3G.
FreeCAD prototype of the modular private smartphone
05/01/2017 at 00:39 • 0 commentsI made a prototype of the modular private smartphone using FreeCAD:
This model will be useful to make a case for the smartphone.
It can be downloaded from the project files:
https://cdn.hackaday.io/files/21260909587840/Modular_private_smartphone.FCStd
Video of the modular private smartphone prototype
04/30/2017 at 21:45 • 0 commentsIn this video I show a prototype of the modular private smartphone, with the following parts:
· Manga screen.
· Raspberry Pi 2 B (in the next prototype the pi zero w will be used).
· Fona 2G (in the next prototype the Fona 3G will be used).
Together with Gerard we made a software to make/receive calls and read/send SMS that you can connect directly to the raspberry pi (without the need of an arduino)
The software can be downloaded from the following link:
Modular private smartphone software
The python file and the png images need to be in the same folder.
For the software to run the following commands need to be used in the terminal:
sudo apt-get install python-serialsudo apt-get install python-toolssudo apt-get install python-qtsudo chmod 777 /dev/ttyAMA0Open modular_private_smartphone_v0.4.0.py with the python IDLE (using python 2.7) and run the module.
imma
