Tool interface
07/24/2017 at 20:09 • 0 commentsThe tool interface is designed to be as useful as possible.
Two outputs are provided:
- 1 electrical single phase line 230 V
- 1 hydraulic circuit
It allows attachments like:
- PTO shaft hydraulic unit (standard interface in agriculture)
- electric motor
- light
- tipper (trailer)
- hydraulic motor
- hydraulic cylinder (e.g. for an excavator shovel)
By default an electric motor is attached. This allows a multitude of implements at the motor shaft, e.g. a gripper for holding a water hose or fork or shovel or hawk or whatever.
Manipulator Environment
07/20/2017 at 07:42 • 0 comments -
Program Toolchain
06/08/2017 at 19:25 • 1 commentProgram
- Completed the transition from Ubuntu to Arch and Void. (huge boost for all projects)
- Void will be used on an ARM soft realtime system with custom software. (machine)
- While Arch is our user system (developer).
- Software modularity:
- Release:
- 0install (for Program, Electronics, ... files)
- Arch.PKGBUILD, Void.template (for buildable sources, either source or pointing to tar.gz package release from 0install)
- Development:
- Git repositories: Very modular approach: Separate all into individual repositories, e.g. if a JavaScript functionality is developed for a web app then it is put into a separate repository and overlaid in the website content|template|base-release repository via git fetch.
This decouples the projects from any release tool dependencies (no matter if e.g. Maven, pip or composer is used for e.g. upstream releases, no need to deal with it)
- Release:
Tested
This process is tested and works. e.g. https://hirschberg-text.de, https://hamag-maschinenbau.de are running entirely based on these universal development procedures.
https://github.com/faerietree/freecad_convert is using the 0install release system which allows to track the release within the repository and is our cross platfrom guarantee. (Note else we only provide Void, Arch Linux packages. 0install is our social component, because we like more gentlemen and ladies to enjoy the freedom wealth we're building.)
Outlook
The website which makes worlddevelopment club far more transparent (open bookkeeping) and content less spread | chaotic ;-) is still under construction. Was busy with the manipulator base: A circular brick and natural stone roundabout where the bot will reside in the middle surrounded by fruit and vegetables to harvest.
Pictures of this in the next news. (currently busy with hay harvest and sorting out manipulator metal bills - and of course the redesign, see most recent Github issue which also explains why the manipulator is so epic: https://github.com/faerietree/manipulator/issues/11)
