Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Sign up Log in
WIoT-2 Station
IoT Info hub displays current/forecast weather, waste collection calendar, links in garage door control, hot tub temp, currency state etc.
daveDave
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.8k views
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
  • The 2017 Hackaday Prize
View Gallery
1.8k
0
4
7
Team (1)
  • daveDave
Join this project's team
  • PlastiBots
Software
ongoing project
blynk iot ESP8266 2017HackadayPrize nextion
Related lists
2017 THP: Digi-Key Parts
Hackaday Prize Entries using Digi-Key parts
This project is submitted for
  • Hackaday.com Tip Line
  • Internet of Useful Things
  • Best Product
This project was created on 05/13/2017 and last updated 6 years ago.
Description
I use it as a cloud-connected (IoT) info center of sorts mounted near our front door. It is a culmination of information my wife or I often look for either on our way out of the house, or when we come home. It displays current/forecast weather from WeatherUnderground, weather outside the house, date, time, our local waste collection schedule, currency rates, the status of our garage doors, our hot tub temperature, and even allows our kids to check-in when the get home. Full write-up with build info / code here: http://www.plastibots.com/index.php/2017/01/03/wiot-2-weather-station-nextion-tft-with-esp8266/
Components
  • 1 × NodeMCU ESP8266 (Mini or Standard size will work) http://www.banggood.com/3Pcs-Mini-NodeMCU-ESP8266-WIFI-Development-Board-Based-On-ESP-12F-p-1058306.html?p=R90804949020201412E4
  • 1 × Nextion TFT LCD 5" http://www.banggood.com/5_0-Inch-Nextion-HMI-Intelligent-Smart-USART-UART-Serial-Touch-TFT-LCD-Module-Display-Panel-p-1113915.html?rmmds=search?p=R90804949020201412E4
  • 1 × PIR sensor http://www.banggood.com/3Pcs-Mini-IR-Infrared-Pyroelectric-PIR-Body-Motion-Human-Sensor-Detector-Module-p-1020422.html?p=R90804949020201412E4
  • 1 × Switching power supply Any buck converter to provide 5V with at least 1AM to the project.
Build Instructions
Collapse
  • 1
    Step 1
    Full How To here at bottom: http://www.plastibots.com/index.php/2017/01/03/wiot-2-weather-station-nextion-tft-with-esp8266/
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
The 2015 Hackaday Prize
A wireless, multiple thermostat home HVAC system
Project Owner Contributor
Multiple Thermostat Home HVAC
emach00Emach00
The home and Society are surrounded by "things" which are connected to each other, either directly or indirectly via the internet of things.
Home automation architecture based on LoRa
ssla-coukssla-couk
Adding a WiFi, NTP and MQTT remote control & measurement unit to a storage heater.
IoT Storage Water Heater Control
keri-szafirKeri Szafir
The 2016 Hackaday Prize
Autonomous intelligent IOT nodes connected to the home network, controlled via simple IFTTT style rules, configured via web interface
WiFi Based Distributed IOT Home Automation
andreyAndrey
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "WIoT-2 Station", please tell us the reason.
Send message
Remove Member
