Wi-PWN (Modern ESP8266 Deauther)
This project was based upon Spacehuhn' WiFi Deauther, but includes loads more features along with a Material Design interface
View on GitHub
Get the app on the Google Play store
Development Discord server
ESP8266 Deauther with a clean & minimalistic web interface — Online demo
Inspired by spacehuhn/esp8266_deauther, it features:
Latest version: https://github.com/samdenty99/Wi-PWN/release
Refer to the GitHub documentation on how to install it.
Wi-PWN.ino.nodemcu.bin
Version 9.0 - Refer to the Github page for the latest version
octet-stream - 570.06 kB - 10/31/2017 at 13:48
Download
Android Package Archive - 1.93 MB - 06/23/2017 at 18:26
Download
  • 1 × ESP8266 A Arduino based board that features a 2.5GHz WiFi chip
  • 1 × Computer + Micro USB cable No other components are needed
  • 1 × Latest Wi-PWN binary Can be found at https://github.com/Wi-PWN/Wi-PWN/releases
  • 1 × NodeMCU-Flasher You use this to flash the binary to the ESP8266
  • 1
    Step 1
    Download the current release of Wi-PWN and nodemcu-flasher.
  • 2
    Step 2
    Connect your ESP8266 to your computer and open up the nodemcu-flasher
  • 3
    Step 3
    Select the the available COM port from the drop-down menu
View all 6 instructions
[deleted]
Sam Denty wrote 08/07/2017 at 02:15 point
@Tejas Lotlikar   No it isn't. You did nothing to contribute to ESP8266_Deauther, except steal the project from Spacehuhn. That was the reason your stolen project was taken down from Hackaday. Go away and troll other people.
I spent time and effort improving his project, but I've stated at the top of the project that it belongs to him
N0vaPixel wrote 08/07/2017 at 17:42 point
Bullshit. Sam Denty designed a responsive and awesome web interface from the original project of @Spacehuhn.
And Tejas Lotlikar ? Apparently nothing, with no contribution to both projects.
So why trying to steal the projects of others ? It's frustrating to see people losing time like this.
Sam Denty wrote 07/24/2017 at 11:33 point
@Piostravino Haven't tested it on the ESP-201 yet, but can you follow the instructions here - https://github.com/samdenty99/Wi-PWN/wiki/Installation and let me know if it works.
If this doesn't work, then I would need the Serial Output of the ESP, which requires you to install Arduino - follow the guide here https://github.com/samdenty99/Wi-PWN/wiki/Compiling-with-Arduino
piostravino wrote 07/24/2017 at 18:47 point
First of all, thank you for the fast reply.
I've tried to follow the compiling-with-arduino tutorial without succes.
I've tried all the 8266 Module but i receiv a problem during the compiling process:
<code>
exit status 1
no matching function for call to 'ESP8266WiFiClass::scanNetworks(bool, bool&)'
</code>
Then i've installed the 2.3.0 version of the 8266 library, and it compile and upload the code to the esp8266-201 using the nodemcu (v 1.0) board. But it still not work.
From the serial monitor it say only:
<code>
ets Jan  8 2013,rst cause:2, boot mode:(7,7)
waiting for host
</code>
but i still not find the ssid with my phone or pc
If i compile the code using the Generic 8266 Module i receive this message from the compiler:
<code>
Arduino:1.8.3 (Windows 10), Scheda:"Generic ESP8266 Module, 80 MHz, 80MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
Archiving built core (caching) in: C:\Users\username\AppData\Local\Temp\arduino_cache_335212\core\core_esp8266_esp8266_generic_CpuFrequency_80,FlashFreq_80,FlashMode_dio,UploadSpeed_115200,FlashSize_512K64,ResetMethod_ck,Debug_Disabled,DebugLevel_None_____a3a3b1e91f7420f89a9ecc0f0e419f58.a
c:/users/username/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\pio\AppData\Local\Temp\arduino_build_882345/Wi-PWN.ino.elf section `.irom0.text' will not fit in region `irom0_0_seg'
collect2.exe: error: ld returned 1 exit status
exit status 1
Errore durante la compilazione per la scheda Generic ESP8266 Module.
(error during compiling for the Generic etc etc)
</code>
Any suggestion?
N0vaPixel wrote 08/07/2017 at 17:58 point
Hi piostravino.
exit status 1
The ESP8266WiFiClass::scanNetworks(bool, bool&) method doesn't exist in the SDK 2.0.0. So you have to do some changes. The new second parameter let you scan for hidden APs.
So follow carefully the tutorial on github to correctly apply the fix.
piostravino wrote 07/24/2017 at 11:27 point
Hi, i've followed and made this project but i can't find the ssid Wi-PWM. i've followed all the instructiion but i've a doubt on the flash part: around the 80% of the flashing process it stops but in the log of the nodmcu flasher i read that the process is finished. Do you have any suggestion? I'm using the esp8266 esp-201 (the white one whit external antenna).
P.S. i've made some screenshots but i don't know how to upload them so here there is a link to a gDrive folder: log image
