FM Modulation in Software
A project log for PB121
A project to replace the Uniden PB121, PB112 boards with modern counterparts to revive dead radios and overcome mcu limitations.
david-l-norrisDavid L Norris 06/08/2017 at 00:181 Comment
David L Norris wrote 06/08/2017 at 00:21 point
Some carrier waveform stability concerns but the FM modulation works well enough that I think it will be trivial to implement.  Particularly if other implementations can be adapted.  Switching to the SI5351 I hope will eliminate ll stability issues.  I have read that some have observed instability with these AD9850 boards in the frequency ranges that we will need to be using; around 40 Mhz or so.
