HR2510 PB112 LCD Display Library
A project log for PB121
A project to replace the Uniden PB121, PB112 boards with modern counterparts to revive dead radios and overcome mcu limitations.
david-l-norrisDavid L Norris 06/08/2017 at 00:330 Comments
A rather boring video of me rambling while spinning the VFO dial and seeing data for the first time.
The code driving the display can be found here:
https://github.com/hamspot/hr2510/tree/master/libraries/HR2510_PB112
It does not work like the standard LCD libraries despite being based on some of that code. It implements a set of methods that are specific to the HR2510 and the things it can display. I expect that there may be other versions of this library created with the same methods for Lincoln/2830, HR2600, TS-5010, CBS-1000, and other variants not listed. Some of the parts between those radios may be more easily interchanged with inexpensive adaptor boards through this project.
PB112 Library Master Mode Example
Pardon the crusty old HR2510 that has been beating around in the truck for a decade or so. But do notice that the above code is driving the display.
