Blimp controller v2.stlThis piece holds the joystickStandard Tesselated Geometry - 248.13 kB - 07/06/2019 at 20:22 |
motors.inoDownload with Blimpy_Server4.inoino - 9.80 kB - 04/07/2019 at 14:55 |
loopMotor.inoDownload with Blimpy_Server4.inoino - 1.12 kB - 04/07/2019 at 14:55 |
Blimpy_Server4.inoCurrent mainino - 2.37 kB - 04/07/2019 at 14:55 |
loopWifi.inoDownload with Blimpy_Server4.inoino - 2.54 kB - 04/07/2019 at 14:55 |
reset.inoDownload with Blimpy_Server4.inoino - 757.00 bytes - 04/07/2019 at 14:55 |
Blimpy_Client.inoJoystick using ESP32ino - 2.47 kB - 12/09/2018 at 23:48 |
sch - 625.89 kB - 12/09/2018 at 23:46 |
brd - 172.39 kB - 12/09/2018 at 23:46 |
UDPClient.inoquick client using the udp libraryino - 1.25 kB - 10/28/2018 at 18:44 |
UDPServer.inoquick server using the udp libraryino - 1.49 kB - 10/28/2018 at 18:43 |
wifi_client_01.inoEasy test pulled from Instructablesino - 1.98 kB - 04/19/2018 at 19:37 |
wifi_server_01.inoEasy test pulled from Instructablesino - 2.12 kB - 04/19/2018 at 19:32 |
ADP2503_2504.pdfBuck-boost converter replaces Vreg rev2Adobe Portable Document Format - 1.50 MB - 01/07/2018 at 22:26 |
TB6612FNG+datasheet.pdfMotor Driver rev 2Adobe Portable Document Format - 300.88 kB - 01/07/2018 at 22:21 |
Adobe Portable Document Format - 129.03 kB - 12/04/2017 at 14:41 |
Adobe Portable Document Format - 2.53 MB - 12/04/2017 at 14:40 |
Inverter gate.pdf74LVCapplication/pdf - 1.38 MB - 10/22/2017 at 22:33 |
Adobe Portable Document Format - 287.05 kB - 10/22/2017 at 22:33 |
MCP73812.pdfBattery chargerAdobe Portable Document Format - 580.61 kB - 10/22/2017 at 14:05 |
ESP8266_client_example.inoThis is a sample client sketch which readtalks to test_server_use_with ESP8266.js SOURCE: https://diyprojects.io/esp8266-web-client-tcp-ip-communication-examples-esp8266wifi-esp866httpclient/#.WVZxFhOrrR1ino - 2.44 kB - 06/30/2017 at 16:55 |
Adobe Portable Document Format - 578.73 kB - 06/18/2017 at 00:06 |
Adobe Portable Document Format - 1.09 MB - 06/17/2017 at 23:37 |
