This is a project that has been designed to measure the most unpredictable element of air pollution: aerosol pollution. It uses a simple physics concept to measure various aerosol concentrations, which will tell you the overall air quality. This device is hand-held, modular, completely Fab-able and easily modifiable. The data from the device is stored on an SD card, as well as integrated with IoT services.
